Brake fluid
art_of_war
Russia
#1 Brake fluid
Post by art_of_war » Thu Aug 25, 2016 12:17 pm
Hello all!
We decided to change the brake fluid and to pump the brakes
The car is Series 1, 3.8, 1962
There are two brake cylinders.
The liquid that was inside is red color ( please see pic attached)
please advise, if this is ok :-) And what is the brake fluid to be used in the car ?? Thank you
:hammerdrill:
vee eight
#2 Re: Brake fluid
Post by vee eight » Fri Aug 26, 2016 7:22 pm
This looks like the very old crimson brake fluid that was available in the UK a long time ago. It was fine to use at that time but is not available now. You would best to flush out all of that fluid from the system (it is more than likely to be quite a few years old) and replace it with a DOT4 fluid.
1967 Series 1 E Type Roadster - 1968 TR5 - 1966 Corvette Stingray Convertible
#3 Re: Brake fluid
Post by chrisfell » Fri Aug 26, 2016 10:12 pm
Er....I wouldn't. I'd use DOT 5.1. Higher heat tolerance than DOT 4. I'd not use DOT 5 under any circumstances. Completely different formula. DOT 4 and DOT 5.1 can be mixed, but best to flush out all the old fluid.
art_of_war
Russia
#4 Re: Brake fluid
Post by art_of_war » Sat Aug 27, 2016 6:46 pm
Thank you friends!
I think I'll use dot 4
I dont race it) thank you
#5 Re: Brake fluid
Post by christopher storey » Sat Aug 27, 2016 9:38 pm
Personally, i would use Dot 3 if you can get it in Russia, as it has better lubricating qualities than the later fluids, and thus you have a better chance of avoiding the sticking seal problem which leads to so many cars having dragging brakes ( this applies particularly to 4.2 with the remote servo )
Springer
Norway
#6 Re: Brake fluid
Post by Springer » Wed Sep 07, 2016 12:59 pm
I know nothing about Dot 3 fluids but I am pretty sure I heard that Dot 5.1 has a better lubricant than Dot 4 if sticky pedal is an issue.
Restauration project of a serie 1 1963 model OTS now running proudly
JagWaugh
Switzerland
#7 Re: Brake fluid
Post by JagWaugh » Wed Sep 07, 2016 4:18 pm
It might also be ATE "racing" fluid. Sometime back around 2013 ATE super blue was taken out of production and a new red one was introduced. IIRC these are all DOT4 compatible. (But the blue is a really effective paint remover.)
