Propshaft bolts/nuts size?
PhilBell
#1 Propshaft bolts/nuts size?
Post by PhilBell » Mon Sep 12, 2016 1:54 pm
Can anyone confirm the correct size for the propshaft flange nuts and bolts please?
I need to fit new nylocs after a the last axle-out job. The ones on there are 9/16in but my parts supplier stocks 3/8in for this application, which seems way too small for the job.
1962 FHC 885626
johnney
#2 Re: Propshaft bolts/nuts size?
Post by johnney » Mon Sep 12, 2016 4:45 pm
3/8" sounds right, they are certainly not 9/16" What did you measure the head size?
johnney
1968 FHC series 1
1E21862
#3 Re: Propshaft bolts/nuts size?
Post by mgcjag » Mon Sep 12, 2016 5:26 pm
Hi Phil....try to get yourself a copy of the SC parts...6 cylinder E type catalogue......lost of diagrams/part numbers and specifications.yoy can pick them up on ebay....they show 3/8unf and half locknuts....cannot remember now but think the full size locknuts might be too thick...
mark10337
Switzerland
#4 Re: Propshaft bolts/nuts size?
Post by mark10337 » Mon Sep 12, 2016 5:30 pm
C19827 bolt with a C8737/3 nut (3/8" half nyloc)
-Mark
#5 Re: Propshaft bolts/nuts size?
Post by abowie » Tue Sep 13, 2016 8:10 am
I suspect the source of the confusion to be nomenclature.
The bolts are 3/8" UNF. This means that the diameter of the bolt is 3/8"
The head size on these is 9/16"AF. So the spanner to fit the head is 9/16" across the flats (AF) of the hex head.
So.. 9/16" AF and 3/8" UNF are one and the same from a practical point of view.
PhilBell
#6 Re: Propshaft bolts/nuts size?
Post by PhilBell » Sun Sep 18, 2016 7:34 am
Thanks for the clarification - the 3/8 UNC nuts do indeed have 9/16 AF heads.
1962 FHC 885626
johnney
#7 Re: Propshaft bolts/nuts size?
Post by johnney » Sun Sep 18, 2016 1:13 pm
Propshaft bolts should be UNF not UNC.
johnney
1968 FHC series 1
1E21862
PhilBell
#8 Re: Propshaft bolts/nuts size?
Post by PhilBell » Sun Sep 18, 2016 7:46 pm
You're right. Too much haste here, didn't read previous posts properly. I blame the stress of contemplating a fourth rear axle removal (for an unrelated problem). Hmmm...
1962 FHC 885626
JagWaugh
Switzerland
#9 Re: Propshaft bolts/nuts size?
Post by JagWaugh » Sun Sep 18, 2016 8:15 pm
Dropping the IRS for the fourth time? Never mind bolts, use drilled pins and cotters!
ETTony
#10 Re: Propshaft bolts/nuts size?
Post by ETTony » Mon Sep 19, 2016 10:05 am
I have just reassembled the back end of mine.
BTW these bolts do have a shoulder so they are a snug fit in the prop shaft holes.
So you do need the correct bolts not simply generic bolts.
Tony in Devon
