Need Jag logo / growler, max. 20 mm diameter
Durango2k
#1 Need Jag logo / growler, max. 20 mm diameter
Post by Durango2k » Sun Sep 25, 2016 5:02 pm
All,
I am fitting 3-point belts in my E.
The only old / period correct ones I have are a very rare static belt set from a very early Citroen Sm. They used latched Cessna-derived belts for the first 6 months, and plastic crap later. They look stunning.
They have an indention on the buckle, 20 mm wide 2 mm deep, a Citroen logo is put in there (a small alloy disc). I removed that, and would love to fit a growler there.
Any source ?
Carsten
iani
#2 Re: Need Jag logo / growler, max. 20 mm diameter
Post by iani » Sun Sep 25, 2016 5:40 pm
Plenty of Jaguar key fobs available with a round growler on them, you'd have to grind the mounting bar off but I think this could be done easily with a dremel for a neat job.
Examples here:
http://classicleatherfobs.co.uk/product ... ry/jaguar/
Ian
Jaguar - 1970 S2 2+2 (sold), 1970 S2 FHC, X150 5.0 XKR, x250 XF x2 (sold) XF SportBrake
1968 Triumph GT6 Mk1
Durango2k
#3 Re: Need Jag logo / growler, max. 20 mm diameter
Post by Durango2k » Sun Sep 25, 2016 5:47 pm
At about 25 to 39 pounds each it is waaaay out, sadly.
Tried ebay, nothing around 20 mm and not cheap either.
Carsten
Stuart Exelby
#4 Re: Need Jag logo / growler, max. 20 mm diameter
Post by Stuart Exelby » Sun Sep 25, 2016 7:20 pm
Carsten - size wise, this is about what you need - but a European source to avoid the horrendous shipping charges.....
http://www.ebay.co.uk/itm/Jaguar-growle ... xy63FSvYbt
1967 Series 1 OTS
Durango2k
#5 Re: Need Jag logo / growler, max. 20 mm diameter
Post by Durango2k » Sun Sep 25, 2016 7:58 pm
Yes, that looks good- sadly no supplier in the old world yet....
Carsten
288gto
Russia
#6 Re: Need Jag logo / growler, max. 20 mm diameter
Post by 288gto » Sun Sep 25, 2016 10:37 pm
Try searching for Jaguar cufflinks or similar.
http://pages.ebay.com/link/?nav=item.vi ... 63&alt=web
Monkeyfinger
#7 Re: Need Jag logo / growler, max. 20 mm diameter
Post by Monkeyfinger » Mon Sep 26, 2016 7:13 am
Just a thought...Another alternative would be to ink jet printer onto glossy adhesive paper. At least would look better than empty space in the short term until you locate exactly the right solution. You would also be able to use any online growler image to get the look you want.
Stuart Exelby
#8 Re: Need Jag logo / growler, max. 20 mm diameter
Post by Stuart Exelby » Thu Sep 29, 2016 6:13 pm
Modern style, but these seem the right size.....
http://www.ebay.co.uk/itm/Jaguar-Herita ... Sw~gRVkqCs
1967 Series 1 OTS
Stuart Exelby
#9 Re: Need Jag logo / growler, max. 20 mm diameter
Post by Stuart Exelby » Sun Dec 18, 2016 5:42 pm
Carsten - don't know if you solved the problem, but this looks to be about the right size - and perhaps a little more in keeping with the period?..... (Expensive perhaps to get a pair, though)
http://www.ebay.co.uk/itm/142215114348? ... EBIDX%3AIT
1967 Series 1 OTS
