Give me a brake?
andrewh
#1 Give me a brake?
Post by andrewh » Wed Nov 30, 2016 6:46 pm
Can anyone tell me the trick for cutting the fabric covered brake vacuum pipe without it all fraying and looking dreadful please? Perhaps I bought the cheap stuff last time, but it turn into a right old mess. Its one of those things I always admire on some other restorations as they are all clean cut and smart.
1962 3.8 Series One FHC
#2 Re: Give me a brake?
Post by cactusman » Wed Nov 30, 2016 7:02 pm
Try binding the place you intend to cut with two wraps of tightly bound electrical tape or gaffer tape. Leave 2-3 mm between the two binds where you intend to cut. Run a really sharp knife around the gap...a fresh Stanley blade is good...to sever the fabric threads. Cut the hose with a hack saw or the sharp blade. Carefully remove the tape. Might be worth applying a layer of paper wrap first before binding to stop the tape actually sticking to the fabric. Then bind really tight to hold the fabric in place. Certainly avoid using a saw to cut the fabric or it will fray badly.
andrewh
#3 Re: Give me a brake?
Post by andrewh » Wed Nov 30, 2016 7:08 pm
yes good advice there, but I did use a rubber pipe shear. Perhaps it wasn't sharp enough for the fabric part? Interested to hear others experiences as well. thanks a lot.
Rustyred
#4 Re: Give me a brake?
Post by Rustyred » Thu Dec 01, 2016 10:03 am
Angle grinder with 1mm cutoff disc, works great and gives super clean cut or Single edge blade to cut the outer sheath then use centre hose cutters. Like these,
https://images-na.ssl-images-amazon.com ... L1500_.jpg
Restoring 73 Series 3 2+2
JagWaugh
Switzerland
#5 Re: Give me a brake?
Post by JagWaugh » Thu Dec 01, 2016 10:16 am
I have tried a few things.
Electrical tape, but this will end up looking ratty with time (and repeated tightening/loosening of the clamp).
Paint the area with a flexible adhesive which dries non sticky - this looks great, but you have to wait until the adhesive dries.
Loom tape, a tape with a fuzzy outer surface, used for repairing wire looms.
The loom tape is my favorite, for the moment.
Andrew
andrewh
#6 Re: Give me a brake?
Post by andrewh » Thu Dec 01, 2016 10:55 am
thanks chaps. I like the cutting disc idea. I did wonder about glue but thought it would look messy once dried. Not keen on taping the ends although I guess if one could place the clip right at the end over the tape that might work?
dal2.0litrefrogeye
#7 Re: Give me a brake?
Post by dal2.0litrefrogeye » Thu Dec 01, 2016 12:15 pm
Cutting disc for a clean cut . And then heat shrink to keep ends tidy . Also heat shrink makes blue or red lucar connectors look uniformly old and not so in ya face modern looking
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
cdaubs
#8 Re: Give me a brake?
Post by cdaubs » Fri Dec 09, 2016 6:35 pm
Just getting in on this a little late, but I just replaced my cloth covered hose from the vacuum tank to the brake bellows. I did buy a quality hose, Aeroquip brand, and although it doesn't have the correct markings it is very good hose. I used a pair of these to cut it.
They are very sharp, cut like a hot knife through butter, and no fraying.
If I'm too late, I hope you were able to make a satisfactory cut.
Charlie Daubs
'64 FHC #890093
andrewh
#9 Re: Give me a brake?
Post by andrewh » Sun Dec 11, 2016 8:36 pm
thanks a lot. No I have not got around to that part of the job yet so will try some of these. Any idea of where they can be bought UK? E bay presumably?
#10 Re: Give me a brake?
Post by Heuer » Mon Dec 12, 2016 11:31 am
After you have cut it you can clean up the frayed fibres by holding a cigarette lighter briefly under the end. This will singe the fibres and cause them to contract and melt into each other.
cdaubs
#11 Re: Give me a brake?
Post by cdaubs » Mon Dec 12, 2016 2:50 pm
The cutters I have are a Sears brand similar to the one I posted (I just grabbed a pic off the web for illustrative purposes). I don't know if you have access to Sears over there. Anyway, this style cutter I have found to be very good for cutting hose and soft material. Not so good for wire or metallic items.
As I said before, no need to melt ends or wrap with tape before or after cutting. They are just great.
Charlie Daubs
'64 FHC #890093
64etype
#12 Re: Give me a brake?
Post by 64etype » Mon Dec 12, 2016 3:17 pm
Aircraft type braided hose is available with black nylon sheathing. It doesn't get grungy looking like cotton, looks virtually the same, and the cigarette lighter trick works perfectly. Since it typically has a stainless layer in the tubing wall, it cuts best with a Dremel cutoff wheel.
Eric
cdaubs
#13 Re: Give me a brake?
Post by cdaubs » Mon Dec 12, 2016 11:16 pm
Sorry it took me so long, but I'm not home. I found the web site I purchased my hose from. $4 per foot, and I bought 7 feet which was more than enough to replace all of the brake vacuum hose.
http://teaguecustommarine.com/em0011/06 ... -hose.html
I hope this helps. :bigrin:
Charlie Daubs
'64 FHC #890093
andrewh
#14 Re: Give me a brake?
Post by andrewh » Sat Dec 24, 2016 5:30 pm
thanks Chaps Lots of good ideas here .
