2 post v Scissor lift
JagNorton
#21 Re: 2 post v Scissor lift
Post by JagNorton » Tue Aug 11, 2026 8:55 am
I'd love a 4 post with a jacking beam, but they are at least 50% more expensive. They both have their advantages and disadvantages I suppose.
Andy
1962 S1 FHC.
#22 Re: 2 post v Scissor lift
Post by mgcjag » Tue Aug 11, 2026 9:06 am
Plenty second hand....as mine in the photo.....even cheaper are 3 phase lifts then just convert to single....as a new member please try to add your name and car model to you signature area...you can just reply to posts without quote copying the previous post as it takes up server space.....there are quite a few 4 post that are reasonably priced...jacking beam you can use a scissor jack and length of steel.....Steve
JagNorton
#23 Re: 2 post v Scissor lift
Post by JagNorton » Tue Aug 11, 2026 9:57 am
Thanks - I've updated my signature. I'll keep a lookout for used options too, although haven't found many as yet. By the time I've added the cost of hiring a van, dismantling and transporting, plus the risk of it not working, it would have to be a very good deal! If anyone reading this knows of one, please let me know.
Andy
1962 S1 FHC.
TGN
#24 Re: 2 post v Scissor lift
Post by TGN » Tue Aug 11, 2026 1:45 pm
Andy 3150mm from outside to outside of the column.
Jag is currently residing at its highest point for the next few days while I finish rebuilding the steering rack.
Message me if you wish to visit.
Trevor.
JagNorton
#25 Re: 2 post v Scissor lift
Post by JagNorton » Wed Aug 12, 2026 4:37 pm
Thanks for the confirmation of the width very much appreciated. I think I might be pushing it a little on height. It really will be so tall its pretty much up against the slates. I need to measure really accurately. However, it does seem like the posts are taller on their inner edge compared to their outer edge which might give me a few more mm. Total height on the drawing is shown as 2860, so I assume that is the inner height. I don't suppose you can do one more measurement for me? The height difference between the inner and outer of the columns. It really is that close.
I definitely owe you a beer! :bigrin:
Andy
1962 S1 FHC.
TGN
#26 Re: 2 post v Scissor lift
Post by TGN » Wed Aug 12, 2026 10:54 pm
I think what you’re seeing is unnecessary plastic covers. It’s been a while since I looked up there.
Trevor.
TGN
#27 Re: 2 post v Scissor lift
Post by TGN » Fri Aug 14, 2026 8:40 pm
Mine goes 2770 without the plastic tops.
Trevor.
JagNorton
#28 Re: 2 post v Scissor lift
Post by JagNorton » Sat Aug 15, 2026 5:49 pm
That's fantastic thank you. I've just done some more accurate measuring and I think I will just about be able to fit this lift in my garage, it's going to be tight, but workable I think.
Really appreciate your help in measuring up :-)
Andy
1962 S1 FHC.
