Wheel arch liners
#1 Wheel arch liners
Does anyone know if wheel arch lines are available for S1 E’s. I can foresee a problem with my all Ali shell, sticky tyres and gravel drive. If there are no specific liners are there any generic that could be adapted?
#2 Re: Wheel arch liners
If you have no joy finding liners, what about a clear vinyl stone chip protection film? 3m do one that is 14mil ( about 0.3mm) thick.
Some sort of protection is probably a good idea. Speaking to Andy at Hutsons who fitted an alloy bonnet to a customer’s car, outward dings from stones hitting the underside were a problem.
#4 Re: Wheel arch liners
Sounds like an opportunity to mould some carbon fibre ones. Would get you bragging rights.
PS will you be painting the bonnet inside and out?
#5 Re: Wheel arch liners
The shell including the bonnet is already painted and the underside including the wings has a light stone chip under the body colour. I am collecting a pair of Ducati rear wing arch liners tomorrow for a look see. Perhaps they can be modified somehow.
More anon.
Pat
More anon.
Pat
dal2.0litrefrogeye
#6 Re: Wheel arch liners
Hi , I'm running an Ali bonnet and so far so good I've done about a thousand miles now , I doubt if sticky tyres on a gravel drive flicking up at driveway speed are going to cause any dings if any damage at all , also sticky tyres aren't usually sticky unless properly up to temp ,
Regards Darren
Regards Darren
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
#7 Re: Wheel arch liners
Since I'm gong for the 'heavy patina' look I'm not too worried. During its pre-modification life as a Lynx bonnet it never got wheel arch dents, but that could be down to stiffening from the heavy layer of skim all over it under the paint.
What about sticking a layer of Flintkote or other dense sound-deadening material direct to the metal, then spraying to match?
#8 Re: Wheel arch liners
Peter, good shout. I will try the Ducato liners first and see if it’s feasible
#9 Re: Wheel arch liners
Ducati arch liners turned up and they are a workable solution for the rears. Could be useful for a road car where you wish to keep the mud off the metal
