3.8 head inlet brass plugs
lyons
#1 3.8 head inlet brass plugs
Post by lyons » Sat Mar 02, 2019 12:48 pm
Head just back from the machine shop and need to replace the 2 large threaded brass plugs on the inlet side that were removed as part of the process.
This was not asked for but I assume that it would be better to seal the threads, so what if anything is recommended ?
Were they originally sealed as they appear clean ?
Mich7920
#2 Re: 3.8 head inlet brass plugs
Post by Mich7920 » Sun Mar 03, 2019 8:09 am
To seal it's HYLOMAR BLUE.
You'll use it also for oil, gazoline, water, air.
Mich
Michel
lyons
#3 Re: 3.8 head inlet brass plugs
Post by lyons » Sun Mar 03, 2019 1:32 pm
Will Hylomar Blue be able to withstand the very high temperature on the cylinder head, bearing in mind these plugs need to be watertight.
Mich7920
#4 Re: 3.8 head inlet brass plugs
Post by Mich7920 » Sun Mar 03, 2019 3:39 pm
Look at Hydormat web
Operating temp -50/ +250°C
Sorry, I really don't know if the cylinder head goes up to 250°C
MIch
Michel
andrewh
#5 Re: 3.8 head inlet brass plugs
Post by andrewh » Sun Mar 03, 2019 5:27 pm
have a look at Wellseal. Developed by Rolls Royce for use on the Merlin. I use it on jobs like this and have never had an issue. But again, check out the website for specifications
1962 3.8 Series One FHC
lyons
#6 Re: 3.8 head inlet brass plugs
Post by lyons » Mon Mar 04, 2019 11:53 am
Thanks all.
Will look at trying Wellseal. It looks like good stuff for jobs like this.
