oil not draining from exhaust cam box.
phoenix
#1 oil not draining from exhaust cam box.
Post by phoenix » Tue Apr 01, 2025 10:22 am
We have a problen with oil smoke from rear bank exhaust. It is ok at first then smokes after 3-4 minutes we think to oil build up . S1 4.2
S1 4.2 RHD Bryan
#2 Re: oil not draining from exhaust cam box.
Post by mgcjag » Tue Apr 01, 2025 11:02 am
There are large drain slots in the head under the came...have you recently had the head off and fitted a head gasket with no corresponding drain holes?...open the oil fill cap if its not draining it will be full.....typically when you switch the engine off you can hear the oil drain down
#3 Re: oil not draining from exhaust cam box.
Post by abowie » Tue Apr 01, 2025 10:41 pm
That's pretty unlikely.
If you're getting smoke out the back I'd be thinking about valve stem seals or piston ring failure.
If it's smoke off the surface of the manifold in the engine bay you have an oil leak; most likely the cam cover gasket.
Allrand
#4 Re: oil not draining from exhaust cam box.
Post by Allrand » Wed Apr 02, 2025 5:50 am
:yeahthat: If the drain hole at the rear of the head or gasket is blocked the whole cam cover would fill up, not just at the rear 3 valves.
Randall Botha
phoenix
#5 Re: oil not draining from exhaust cam box.
Post by phoenix » Thu Apr 03, 2025 12:15 pm
Checked with spare gasket and it has the same holes either way up.
S1 4.2 RHD Bryan
#6 Re: oil not draining from exhaust cam box.
Post by mgcjag » Thu Apr 03, 2025 2:45 pm
The spare isn't the one you have fitted....is the oil draining or not?.
This isnt difficult..remove the covers and check that oil is draining
