Where does this go?
dmarsh2426
#1 Where does this go?
Post by dmarsh2426 » Sat Jul 26, 2025 3:43 pm
I have refurbished my 4 speed gearbox in my '67 OTS: new bearings, new companion shaft, new thrust washers, new seals, and new synchros. I have reassembled it and it seemed to shift fine. It is back in the car now.
The other day, under my workbench I found a small spring. It is smaller and less dense than the detent springs as seen in the second photo. It is tapered as well.
I dont remember seeing other springs like this while I was rebuilding the gearbox.
It is almost the size of a spring from a ballpoint pen, but is heavier.
Needless to say, I do not look forward to removing the engine and gearbox again, but I guess I will have to if this is indeed integral to a functioning gearbox.. :banghead:
Dan
Paul bow
#2 Re: Where does this go?
Post by Paul bow » Sat Jul 26, 2025 7:34 pm
Well I’m afraid I do not know the answer to that but certainly know a very helpful Ken at klassic English transmissions, who as said very helpful and knows more about these g/boxes than anyone should do ..
find his number below if you get no answers from the others on here…hope that helps.
07801 882771.
S1 2+2 manual. (Sold)
dmarsh2426
#3 Re: Where does this go?
Post by dmarsh2426 » Sun Jul 27, 2025 12:18 am
Great, thank you. I will give him a call.
#4 Re: Where does this go?
Post by abowie » Sun Jul 27, 2025 4:06 am
I don't recall any springs inside the gearbox that look like that.
I can only assume that one end of the wormhole that eats springs in my workshop exits under your bench...
dmarsh2426
#5 Re: Where does this go?
Post by dmarsh2426 » Sun Jul 27, 2025 1:14 pm
I wondered where those have been coming from!
I may have some of your washers too.
angelw
#6 Re: Where does this go?
Post by angelw » Mon Jul 28, 2025 10:32 pm
Hello Dan,
For absolute certain, that spring didn't come out of your gearbox, unless someone during previous work, inadvertently dropped this foreign item into the gearbox.
dmarsh2426
#7 Re: Where does this go?
Post by dmarsh2426 » Sat Aug 02, 2025 2:39 am
Thank you
