Headlining sides remove
00series
#1 Headlining sides remove
Post by 00series » Fri Jun 30, 2017 10:27 am
Hi, I'm currently at the trimmers helping to remove and refit a new Aldridge trimming headlining kit ( trimmer has not fitted one before before) - it's a full kit as the sides are grubby and sagging not just the main center price. We are trying to remove the headlining sides from my S2 2+2. I have removed the main headlining but I'm now having trouble removing the side pieces of the headlining that sit above the can't rails. Does anyone know how how to remove these please? Thanks, Bert
#2 Re: Headlining sides remove
Post by mgcjag » Fri Jun 30, 2017 10:43 am
This post may help.but it shows them being trimmed in situe...i think what your pointing to is non removable its part of roof structure viewtopic.php?t=2838
00series
#3 Re: Headlining sides remove
Post by 00series » Fri Jun 30, 2017 12:45 pm
Thanks - I removed the door rubbers. Unscrewed and can't rails I now have good access to the side areas of the headlining. Regarding the cant rails, is there a trick to removing the thin chrome edge trim as while the cant rails are out it would be good to retrim them? Thanks Bert
#4 Re: Headlining sides remove
Post by mgcjag » Fri Jun 30, 2017 1:25 pm
Hi Bert....done this recently on my S2 2+2.....there is no trick....on the reverse side there are a couple of metal retainers rivited holding it in place....and if you look carfully on the rear side of the chrome its been crimped on....so needs very carefull prising off......the problem is getting it back on........you need to widen the opening......along its entire length......i put a screwdriver in it vertically and pulled it along the slot to widen..but take care....also i recovered over the existing vinyl for fear of ripping up the foam core by pulling the old vinyl off.....so that the extra layer does not interfear with getting the chrome back on i trimmed off the old vinyl from the whole length of the lip front and back that the chrome fits on.....re chrimped with pliers but tape up the jaws so they dont damage the chrome.......its not an easy job but well doable.....all the best.. Steve
00series
#5 Re: Headlining sides remove
Post by 00series » Fri Jun 30, 2017 3:44 pm
Thanks steve - that all makes perfect sense, cheers Bert
Polse7317
#6 Re: Headlining sides remove
Post by Polse7317 » Sat Jul 01, 2017 6:25 am
If it can help......
Imagehttps://img4.hostingpics.net/pics/937413cr12.jpg[/img][/url]
paydase
#7 Re: Headlining sides remove
Post by paydase » Sat Jul 01, 2017 12:19 pm
Merci Yves, that's really helpful.
Btw, I checked that these pics are still on your restoration thread, so not hijacked by Photofucket :lol:
Your pics are most useful for inside trimming.
Serge
1964 (3.8) FHC
1961 OTS
