Source of these self-tapping nut-plates anyone ?
rfs1957
#1 Source of these self-tapping nut-plates anyone ?
Post by rfs1957 » Sat Feb 04, 2017 11:48 am
Having trouble finding these with the correct deep throat.
Easy to find ones with about 3/8" edge-to-centre spacing, but these 5/8" ones were used in many places on my 1962 car and I haven't found a Usual Suspect that has them.
Where do people buy / source these please ?
Seen here, under-dash knee panel fixings, lower edge.
norman m. macleod
#2 Re: Source of these self-tapping nut-plates anyone ?
Post by norman m. macleod » Sat Feb 04, 2017 1:58 pm
Hi Rory,
If you Google "Bresco-Spire nuts", they have a pretty good selection, various sizes and edge set-backs, I've always found what I needed there......
Norman
:Scotland:
1967 S1 2+2
#3 Re: Source of these self-tapping nut-plates anyone ?
Post by mgcjag » Sat Feb 04, 2017 2:10 pm
Hi Rory...SNG do have different sizes....you just need to look up the part number for the ones you need..can all be found by looking at the various diagrams on there site
wilkinsi
#4 Re: Source of these self-tapping nut-plates anyone ?
Post by wilkinsi » Sun Feb 05, 2017 9:59 am
Hi Rory,
I had exactly the same problem on my 62 FHC with the lower front bulkhead clips and found a supplier here in Melbourne, Australia with the correct items that fit perfectly
The company is Rare Spares web address is http://www.rarespares.net.au and enter NU0002 into the search engine which will bring up the product which is of good quality and zinc plated.
Ian Wilkins
#5 Re: Source of these self-tapping nut-plates anyone ?
Post by Gfhug » Sun Feb 05, 2017 10:10 am
Rory, will any of these work?
https://www.lasaero.com/site/products/a ... =U00OKAGZV
A great source for hardware, a bit more expensive as they are of aircraft standard, but one advantage of buying your nuts and bolts from them is they come cadmium plated
rfs1957
#6 Re: Source of these self-tapping nut-plates anyone ?
Post by rfs1957 » Sun Feb 05, 2017 2:18 pm
Thanks to everyone ; Bresco say "deep" but not how deep, the Aero lot stops at 0.50" whereas the Jag one is 5/8", and Melbourne sounds lovely as a last resort !
Have asked Bresco for some sizes, and as SNGB are being super-reactive over the complains aired elsewhere (about clutch-bottles) I'll ask them too ............
#7 Re: Source of these self-tapping nut-plates anyone ?
Post by mgcjag » Sun Feb 05, 2017 3:15 pm
#8 Re: Source of these self-tapping nut-plates anyone ?
Post by Heuer » Sun Feb 05, 2017 3:22 pm
Have you tried Richard Smith?
rfs1957
#9 Re: Source of these self-tapping nut-plates anyone ?
Post by rfs1957 » Mon Feb 06, 2017 4:55 pm
No, David, never used him to date - what's the speciality ?
SNGB have them as BD86331 here, and have confirmed the 5/8" throat :
http://www.sngbarratt.com/PartSearchRes ... no=BD86331
These will probably work but are clunkier than the originals at 15mm x 30mm instead of 11.2mm x 24mm, and they are of the U-type instead of the J type, AND they don't self-locate.
Bosco have them here, SNU1561, 5/8" throat confirmed, to suit #8 screws, and the sizes are better ; it is still a "U" type and not a "J" type but, critically, it does appear to have the indent that makes it self-locating :
http://www.bresco.com/acatalog/-U--nut- ... tml#SID=86
I'll order some and find out. And have contacted Richard Smith.
rfs1957
#10 Re: Source of these self-tapping nut-plates anyone ?
Post by rfs1957 » Sat Feb 11, 2017 10:44 am
Bump for above, after the update.
rfs1957
#11 Re: Source of these self-tapping nut-plates anyone ?
Post by rfs1957 » Sat Feb 18, 2017 5:45 pm
Delivered : these supplied by Bresco are indeed as close to identical as matters, self-locating and exactly the same size as the original.
