Prop shaft sleeve yoke position
Maikel
#1 Prop shaft sleeve yoke position
Post by Maikel » Thu Jun 22, 2017 2:56 pm
Simple question short answer.
At which end is the prop shaft sleeve yoke mounted? Gear box or diff and why?
Maikel
Hugo
#2 Re: Prop shaft sleeve yoke position
Post by Hugo » Thu Jun 22, 2017 3:06 pm
Propshafts always have the spline at the front as far as I'm aware. No idea why this should make any difference though. I suppose on the Jag with its fixed position diff, this will mean less mass being thrown backwards and forwards, but on other more conventional cars the opposite I would imagine.
Geoff Green
#3 Re: Prop shaft sleeve yoke position
Post by Geoff Green » Fri Jun 23, 2017 12:36 am
Hugo,
Where the slip joint goes depends on the drivetrain. I do not have my e-type info handy, however XJ-S has one orientation for Borg Warner transmission and the opposite for the Turbo Hydromatic.
Must check... Don't guess.
Maikel
#4 Re: Prop shaft sleeve yoke position
Post by Maikel » Fri Jun 23, 2017 6:42 am
:scratchheadyellow:
that is why I am asking. Someone should know for sure. Strange it is nowhere noted.
Maikel
Hugo
#5 Re: Prop shaft sleeve yoke position
Post by Hugo » Fri Jun 23, 2017 7:02 am
Geoff Green wrote:Hugo,
Check how? It's certainly a good question. I can't see any logic in having different orientations for different gearboxes. Maybe it's just the way the fitters put them on when they worked on the cars? Oops, I'm guessing again ;)
JagWaugh
Switzerland
#6 Re: Prop shaft sleeve yoke position
Post by JagWaugh » Fri Jun 23, 2017 7:08 am
My instinct would be to put it so that spray and grit is less likely to be "pushing" it's way past the seal on the splined section.
#7 Re: Prop shaft sleeve yoke position
Post by mgcjag » Fri Jun 23, 2017 7:48 am
See the manual page G.3...Propshaft with needle rollers and sliding spline at the front end.
Maikel
#8 Re: Prop shaft sleeve yoke position
Post by Maikel » Fri Jun 23, 2017 12:03 pm
Steve,
WELL DONE !!!!
Hugo
#9 Re: Prop shaft sleeve yoke position
Post by Hugo » Fri Jun 23, 2017 12:08 pm
But it still doesn't say WHY the front not the back?
Maikel
#10 Re: Prop shaft sleeve yoke position
Post by Maikel » Fri Jun 23, 2017 12:22 pm
Probably less dirt and maybe easier to grease during maintenance as the early prop shaft had a grease nipple for the sleeve yoke.
But I can now install the shaft and then the engine.
Apropos just opened another topic regarding broken automatic flywheel.
Hugo
#11 Re: Prop shaft sleeve yoke position
Post by Hugo » Fri Jun 23, 2017 12:32 pm
It is universal practice as far as I'm aware. I'd like to find out why? It would be easier at the back on an E Type, wouldn't it?
