Post
by rswaffie » Fri Feb 02, 2018 3:49 pm
Thanks Andrew,
The IRS is not in yet - still a bare shell except for the front brakes/suspension etc. The Barratt part shows the ribbed spigot inside a large nut that inserts into the plastic pipe. Those are the parts I don't have. The fuel line comes with just the nut on the end of the line so I'm assuming that once it's fully tightened, there must be a flare or flange on the end of the line that seals it to the threaded bulkhead connector. I'll have another look at it tonight.
