Help S2 Manual gearbox problem
Classic
Spain
#1 Help S2 Manual gearbox problem
Post by Classic » Tue Oct 01, 2019 11:48 am
I’m tyding up my 1969 S2, water circuit already done and front suspension refurbishment shortly on the way.
Meanwhile I’m having some problems with the gearbox for which I need your help.
Third gear cannot be engaged from time to time and when this happens i cannot alternatively go into 4th nor second without heavy grinding. Rest of gears goes reasonably well, it is only, and not always, when i go from second to third. Fourth to third is ok too! I recenctly changed gearbox oil and put SAE90 but to no avail.
I guess my options are (from hopefully cheaper to dearer):
- try with some other gbox oil to see if that helps
- take the gbox out and mend whatever it is
- look for a seconhand/rebuilt suitable gbox (wonder if XJs can be used?)
- go for a full monty and get a 5 gear box (it will help my 3.55 diff too)
Can you please advice me in assesing what could be the problem with my box and what would be your recommendation?
Unfortunately money is somehow object!
Live is too short, Carpe Diem my friend
#2 Re: Help S2 Manual gearbox problem
Post by politeperson » Tue Oct 01, 2019 12:25 pm
Do you have full clutch disengagement?
Maybe the clutch is dragging a little and your push-rod needs extending?
Classic
Spain
#3 Re: Help S2 Manual gearbox problem
Post by Classic » Tue Oct 01, 2019 1:47 pm
politeperson wrote: ↑
Thks politeperson
I’d say yes, it does disengage fully, otherwise i’d have problems in other gears as well and/or clutch slippage, which i dont have either. Just my guess
#4 Re: Help S2 Manual gearbox problem
Post by abowie » Tue Oct 01, 2019 9:40 pm
It sounds like either selector fork or possibly synchromesh problem to me, either of which are probably only going to be fixable by rebuilding the gearbox.
Before you do this though change your oil to Redline MT 90. Many of us use it in our all synchro boxes. It might help.
Classic
Spain
#5 Re: Help S2 Manual gearbox problem
Post by Classic » Wed Oct 02, 2019 9:46 am
abowie wrote: ↑
Thanks abowie, I’ll try the redline MT 90 first if I find in Spain!
Classic
Spain
#6 Re: Help S2 Manual gearbox problem.SOLVED
Post by Classic » Wed Mar 25, 2020 12:28 pm
I forgot to post what happened in the end!
It was just the routing of the stick. Depending how you throw it it will engage or not possibly due to some little missalignment on the shifting drives below the stick.
Now that i know, it always works
tinworm
#7 Re: Help S2 Manual gearbox problem
Post by tinworm » Wed Mar 25, 2020 1:44 pm
Well the problem may be in the selector rods/forks in the gearbox lid. Worthwhile having a look. In answer to a question from your original post - yes you can use an XJ6 series 1 gearbox for spares - the series 2 though used a beefed up reverse idler and cluster gear . Its worth hanging on to an incomplete (I buy them without the O/D) box - just in case.
Barrie
