I’m tyding up my 1969 S2, water circuit already done and front suspension refurbishment shortly on the way.
Meanwhile I’m having some problems with the gearbox for which I need your help.
Third gear cannot be engaged from time to time and when this happens i cannot alternatively go into 4th nor second without heavy grinding. Rest of gears goes reasonably well, it is only, and not always, when i go from second to third. Fourth to third is ok too! I recenctly changed gearbox oil and put SAE90 but to no avail.
I guess my options are (from hopefully cheaper to dearer):
- try with some other gbox oil to see if that helps
- take the gbox out and mend whatever it is
- look for a seconhand/rebuilt suitable gbox (wonder if XJs can be used?)
- go for a full monty and get a 5 gear box (it will help my 3.55 diff too)
Can you please advice me in assesing what could be the problem with my box and what would be your recommendation?
Unfortunately money is somehow object!
Help S2 Manual gearbox problem
#1 Help S2 Manual gearbox problem
Live is too short, Carpe Diem my friend
#2 Re: Help S2 Manual gearbox problem
Do you have full clutch disengagement?
Maybe the clutch is dragging a little and your push-rod needs extending?
#3 Re: Help S2 Manual gearbox problem
Thks politepersonpoliteperson wrote: ↑Tue Oct 01, 2019 12:25 pmDo you have full clutch disengagement?
I’d say yes, it does disengage fully, otherwise i’d have problems in other gears as well and/or clutch slippage, which i dont have either. Just my guess
#4 Re: Help S2 Manual gearbox problem
It sounds like either selector fork or possibly synchromesh problem to me, either of which are probably only going to be fixable by rebuilding the gearbox.
Before you do this though change your oil to Redline MT 90. Many of us use it in our all synchro boxes. It might help.
#5 Re: Help S2 Manual gearbox problem
Thanks abowie, I’ll try the redline MT 90 first if I find in Spain!abowie wrote: ↑Tue Oct 01, 2019 9:40 pmIt sounds like either selector fork or possibly synchromesh problem to me, either of which are probably only going to be fixable by rebuilding the gearbox.
#6 Re: Help S2 Manual gearbox problem.SOLVED
I forgot to post what happened in the end!
It was just the routing of the stick. Depending how you throw it it will engage or not possibly due to some little missalignment on the shifting drives below the stick.
Now that i know, it always works
#7 Re: Help S2 Manual gearbox problem
Well the problem may be in the selector rods/forks in the gearbox lid. Worthwhile having a look. In answer to a question from your original post - yes you can use an XJ6 series 1 gearbox for spares - the series 2 though used a beefed up reverse idler and cluster gear . Its worth hanging on to an incomplete (I buy them without the O/D) box - just in case.
Barrie
Barrie
