#1 Engine mount torque settings
Posted: Wed Apr 01, 2020 10:17 am
by Grant
Good Morning Everybody
Another Isolation job !
If it wasn’t for earning no money what’s so ever I could really get used to this :-)
But I’m just about to try changing my front engine mounts on my driveway mostly from above I guess ,
But was wondering if anyone new where I can find the torque setting if there are any ? Or is it just ft ?
Any other tips doing this great fully received
Thank you
Grant
#2 Re: Engine mount torque settings
Posted: Wed Apr 01, 2020 10:32 am
Hi Grant...always worth useing the search function....I doubt there,s much that isnt already on the forum.....u may find shims under your mounts..possibky stuck to them or the frame...these were used as required from the factory..probably to ease a bit of clearance for carbs etc from the frames...
viewtopic.php?f=4&t=3688
#3 Re: Engine mount torque settings
Posted: Wed Apr 01, 2020 10:34 am
by tim wood
I’ve just done mine,
Couldn’t find a torque setting so gave the centre bolts a good hard tug using a 24” bar. Can’t see them coming loose.
Likewise with the money side, pensions cover the day to day and a bit of part time covers garage activities.
Tim
Edit, just seen Steve’s post. I added one shim under the carb side. (Gratefully donated by a forum member some time ago)
#4 Re: Engine mount torque settings
Posted: Wed Apr 01, 2020 10:47 am
by christopher storey
There is no need for a torque setting for these, since they are not under dynamic load . With all due respect to Tim, a hard tug on a 24 inch bar sounds like over-torqueing by a considerable margin, and the paradoxical effect of this is to stretch the stud which enables it to self loosen much more easily . I can't remember what size these are , but IIRC it is something like 3/8 UNF, and 30 lb/ft will be ample in this usage
#5 Re: Engine mount torque settings
Posted: Wed Apr 01, 2020 10:52 am
by Grant
Hi All
Thank you for such quick replies, I’m just having fun finding a jack low enough to support the sump with a piece of wood on it as well .
And thank you for point out the shimes , funny cause I have search here but not really found much . But I will look out for the shimes now ,
And try the 30lbs of torque as I have very little idea about this ,
Thank you all again
#6 Re: Engine mount torque settings
Posted: Wed Apr 01, 2020 12:04 pm
by tim wood
When I’m out in the garage a bit later. I’ll check the torque and se how hard I pulled!
Maybe interesting
Tim
#7 Re: Engine mount torque settings
Posted: Wed Apr 01, 2020 6:02 pm
by Grant
Hi Guys
Well that was a bit of a job! Although they aways are ....
After cutting four bits of 8 x 2 to raise the car high enough so I could get a jack with wood on it underneath to support the engine whilst I undid the mounts.
It’s obviously very fiddly but do able , the right hand side went very smoothly although it was completely shot but the left one rubber part decided to just disintegrate, which meant the metal threaded centre just went round and round.
After trying mole grips and even lowering in back down to put weight on it I finally decided to take the whole metal mount off, again a pain to get to but after some perseverance I finally got it off then had to put it in the vice to separate them.
Then the same all in reverse with a few grazed knuckles it’s back on its wheels and tightened up to just under ft!
All in all a tough but do able job that was very needed and satisfying to do .
Thanks again for all your input
I hope this may help the next person
Grant
#8 Re: Engine mount torque settings
Posted: Wed Apr 01, 2020 6:03 pm
by Series1 Stu
christopher storey wrote: ↑Wed Apr 01, 2020 10:47 am
I'm sorry Christopher bit I have to disagree. There is always a need for a torque setting and the engine mounting bolts certainly are under dynamic load. Try running your car without any fitted.
My engine mounting bolts are 1/2" UNF between engine and rubber mount and the mount to frame bolts are 5/16 UNF. I would suggest around 17 lbf.ft for the mount to frame bolts and 75 lbf.ft for the engine to mount bolts. Do not lubricate the threads.
Remember, for every nut a washer and for every joint a torque value (as a proxy for clamping force).
#9 Re: Engine mount torque settings
Posted: Sat Apr 04, 2020 5:14 pm
by tim wood
Well, with nothing better to do today I went to check these.
Originally pulled with a good firm tugs on a 24” bar, the thread suggests 75ft/lbs
I could only get access to the exhaust side and with my torque wrench mine were not so far off.
Not sure what this means but I’m happy !
