Rev counter checking
PierreW
#1 Rev counter checking
Post by PierreW » Thu Aug 17, 2023 4:53 pm
As I had doubts about the reliability of my rev counter, I compared it with that of my MK2. I plugged in a precise DC stabilized power supply in place of the camshaft generators and increased the voltage in 1 volt increments. Here are the results which will also allow you to check the proper functioning of your rev counters. Everything seems correct to me on the side of my instrument ... now I have to look elsewhere why the displayed speed never exceeds 3000 rpm.
Jaguar MK2 1967 since 1980
Lotus Seven 1963 since 2015
XKE S1 1964 OTS since 2023
#2 Re: Rev counter checking
Post by DWW » Thu Aug 17, 2023 5:28 pm
Thanks, very useful I am sure. Probably a tired generator.....
PierreW
#3 Re: Rev counter checking
Post by PierreW » Thu Aug 17, 2023 5:57 pm
That's what I thought at the start already, that's why I took it apart and saw that the bronze bearing had sunk all the way. I :twisted: degreased it as well as possible and re-sealed it with loctite blockpress. The mechanical drive is done correctly now and I don't know what's still wrong... :evil:
#4 Re: Rev counter checking
Post by DWW » Fri Aug 18, 2023 2:51 am
PierreW
#5 Re: Rev counter checking
Post by PierreW » Fri Aug 18, 2023 3:15 am
both have the same defect as mine had: the bronze bearing is no longer crimped and has moved backwards. So either the mechanical drive is no longer done or the magnetic induction in the coil is disturbed. :evil:
And they have the nerve to sell defective parts at a very high price. :twisted: :twisted: :twisted: :twisted:
#6 Re: Rev counter checking
Post by DWW » Fri Aug 18, 2023 11:44 am
I see what you mean😡
PierreW
#7 Re: Rev counter checking
Post by PierreW » Sun Sep 22, 2024 8:35 am
Was the tired generator ! viewtopic.php?f=4&t=21004#p170498
