Wiper Motor 5-way connector block clamp C2796
#1 Wiper Motor 5-way connector block clamp C2796
My car is drilled for this, although I can find no reference to it in any J30 listings, be it body, wiper motor, or electrical accessories.
The one shown is a rather amateur attempt.
I searched with all sorts of keywords to no avail on either the Forum or on SNGB, but finally ran them aground here :
http://coventryautocomponents.co.uk/sto ... arch=c2796
which enabled me to back-track to here :
https://www.sngbarratt.com/Francais/#/f ... Down=false
Just thought I would put this up FWIIW on the Forum to help someone else in their searches.
#2 Re: Wiper Motor 5-way connector block clamp C2796
That is the wrong bracket Rory! From our 'Factory Fit' thread:
Part #C17435 Fixing strap for 5 way connector block #3571 on screen wiper cable. Missing on many cars for some reason (probably because it is a bugger to get on):
https://www.sngbarratt.com/Francais/#/u ... Down=false
The bump in the bracket is to accomodate a 6th solo connector.
S1 OTS OSB; S1 FHC ODB
#3 Re: Wiper Motor 5-way connector block clamp C2796
Should this be present on S2 cars or do they have a different setup?
#4 Re: Wiper Motor 5-way connector block clamp C2796
The C.2796 bracket is used for the 5 way headlamp connector on RH side of bonnet and C.2532 bracket for the 8 way connector on the LH side of the bonnet. The S2 uses bracket C.1040/14 to secure the wiper harness to the bulkhead.
#5 Re: Wiper Motor 5-way connector block clamp C2796
Oh dear, not doing very well am I.
Makes sense, there are after all 6 wires ..........
Is this proof Lucas couldn't be ar--d to make a 6-way connector ?
Another part into the SNGB basket then.
#6 Re: Wiper Motor 5-way connector block clamp C2796
Use a single connector on one of them; it tucks into a groove and if you look at David's post above the correct bracket has a little bulge for it.
#7 Re: Wiper Motor 5-way connector block clamp C2796
It's a tight fit but it does work.
1965 S1 4.2 FHC (early)
#8 Re: Wiper Motor 5-way connector block clamp C2796
#9 Re: Wiper Motor 5-way connector block clamp C2796
Would anyone have an original one to hand ?
I've now got the SNGB version.
My car has two 3/16" holes at 1-1/2" separation, or say on 38mm centres.
The SNGB bracket's holes will not even take an 1/8" rivet, and they are on 41mm centres.
Well, "bend it tighter and drill the holes out", I hear you say.
Except the connectors are such a tight fit already that they will be crushed by 3mm of squeezing.
In fact if I were to clamp the bracket against any flat surface, even without the sideways squeeze, they will be deformed, such is the tight fit.
I'm also intrigued by the fact the steel sheet used is 1.5mm thick, or 60 thou, which seems massively excessive - it's a clip, for heaven's sake.
What was the Jaguar one like, please ?
#10 Re: Wiper Motor 5-way connector block clamp C2796
There are only 5 wires that need to be connected, the sixth (black) is an earth which can have a ring terminal secured to one of the wiper mounting bolts. originally it used a bullet connector as shown above but the repro connectors are too thick so either source an original or make your own bracket to fit.
#11 Re: Wiper Motor 5-way connector block clamp C2796
Rory,
Measuring in situ, so not 100% correct perhaps, my original bracket is 19mm from the firewall face to the inside flat face of the bracket, and is somewhat less than 1mm thick. Bends on the original are much more crisp, and center to center mounting is about 37mm.
SNG seem to frequently get their sheetmetal products dimensions and thicknesses wrong (this bracket, radiator fan shroud lower brackets, bonnet latch brackets, are some that come to mind as items I've tossed as unsuitable)
#12 Re: Wiper Motor 5-way connector block clamp C2796
Thanks for that from both of you.
The 5 wires are indeed required for my ensemble, David, you may have forgotten the separate green one to the LHS of the wiring diagram
I’ll send this bracket back ; would it cost more to make ones that fitted ?
But ‘twas ever thus.
#13 Re: Wiper Motor 5-way connector block clamp C2796
The wiring diagram shows the switch on the left and the motor on the right. The green wire is in the dash and connected to the switch (as is the red/white for the park) and not wired to the motor
The original connector is a 4 way (Lucas did not produce a 5 way) so Jaguar added a single extra connector with a bracket to match. The hole in the centre of the 4 way is not meant to be for a connector but there to allow for compression. So 5 wires connecting the motor with the sixth black wire going to an adjacent earth.
#14 Re: Wiper Motor 5-way connector block clamp C2796
Interesting point that David, about the 4-way having a 5th hole.
I had understood that there was indeed a true 5-way connector, as seen here :
https://www.thebonnevilleshop.com/produ ... pn-850832/
but maybe they were in fact not in use in 1962.
https://classiccarparts.co.nz/bullet-co ... ation-3570
I'm puzzled by your interpretation of the diagram you have shown, as the famous Coventry Auto booklet sold by Autosparks, showing a detailed breakdown of the different circuits, seen above and below, ties in perfectly with their loom.
The Autosparks Series 1 loom has 6 wires going to the wiper motor, which is April 1962.
Harness : Red/Green - Yellow/Green - White/Green - Brown/Green - Blue/green - Green
Motor : Red/Green - Yellow/Green - White/Green - Brown/Green - Blue/Green - Green/Black
(the earth on the motor is direct/separate and not in the loom)
My understanding is that the switch is on the right of your diagram (which is why the poles are numbered, as is the switch) and has 5 wires plus an earth, with the motor on the left of the diagram, having 6 wires plus an earth that is not shown.
The title should perhaps have read Screenwiper Motor and Switch ?
#15 Re: Wiper Motor 5-way connector block clamp C2796
You are correct Rory. The following document from the Forum KB fully explains the operation of the Lucas DL3 Wiper Motor operation and wiring: https://www.dropbox.com/s/hxrf5x1ws1zac ... s.pdf?dl=1
I should have remembered the DL3 motor is always 'live' and the switch provides the earth, which is counter intuitive. The S2 15W wiper motor works the opposite, the switch provides a live and the motor is earthed. Sorry for the confusion! My car has the Lucas DL3A wiper motor which is three wire and has the park switch on the motor itself. It was used only on S1.5 LHD cars despite being a far superior solution hence why I use it.
#16 Re: Wiper Motor 5-way connector block clamp C2796
Phew, I wasn’t dreaming. For once.
If I want to stock-up on a back-up system, David, what’s the approved route for finding a DL3A such as you mention ?
#17 Re: Wiper Motor 5-way connector block clamp C2796
The DL3A was only fitted to US export LHD S1.5 cars but also used on other British cars whose electrical engineers were obviously way brighter than those at Jaguar.
Usually on eBay e.g. https://www.ebay.co.uk/itm/364510017646 ... R-CW6-jjYg
Although that one is not exactly the same version as Jaguar used so may require modification to mount.
