Courtesy light drama
dlgis
#1 Courtesy light drama
Post by dlgis » Wed Aug 14, 2024 3:34 pm
One of my courtesy light switches has broken in two and the wiring has dropped into the bodywork :roll: What’s the best way to get at the wiring to poke it back out the courtesy switch hole? Bearing in mind I'd like to minimise disruption to my lovely new interior trim 🫤
Thanks all
Darryl
Iansparky
#2 Re: Courtesy light drama
Post by Iansparky » Wed Aug 14, 2024 3:55 pm
You could try putting a bend in a piece of thin stiff wire and wiggle it around inside the hole hopefully you can catch the switch wiring in the hook and pull it back through
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
dlgis
#3 Re: Courtesy light drama
Post by dlgis » Wed Aug 14, 2024 5:15 pm
Hi Ian i did try that but no luck, i’ll give it another go tomorrow but no luck on the first attempt 🫤
Darryl
Allrand
#4 Re: Courtesy light drama
Post by Allrand » Wed Aug 14, 2024 5:56 pm
Same thing happened to me, managed to fish it out with a piece of wire with a hook bend on the end.
Randall Botha
johnetype
#5 Re: Courtesy light drama
Post by johnetype » Wed Aug 14, 2024 7:36 pm
No workshop should be without one of these:
https://www.ebay.co.uk/itm/314650556882 ... 6X69FV8XGN
1969 Series 2 FHC
Monkeyfinger
#6 Re: Courtesy light drama
Post by Monkeyfinger » Thu Aug 15, 2024 9:35 am
Along with the above advise, I can recommend one of the very cheap endoscope camera attachments for use with a phone. Whilst the quality is not great, it would be good enough to see if your fishing technique is at all close to the prize. These start at around 8GBP on Ebay and on other sites. A myriad of uses around the home.
dlgis
#7 Re: Courtesy light drama
Post by dlgis » Thu Aug 15, 2024 11:01 am
Thanks John I've invested in one of those essential tools 👍 and Richard a camera is a good plan, unfortunately mine broke a couple of months ago so I’ll order up another 😊 and try further exploration with some bent wire in the meantime :fingerscrossed:
Darryl
Monkeyfinger
#8 Re: Courtesy light drama
Post by Monkeyfinger » Thu Aug 15, 2024 11:56 am
Can we approach you for some private medical work following a successful wire retrieval? :bigrin:
rfs1957
#9 Re: Courtesy light drama
Post by rfs1957 » Fri Aug 16, 2024 7:22 am
Can anyone volunteer some experience with these cameras, purchase links or WHY ?
Happy to pay proper money for a 10 year lifespan if it’s possible to avoid effing TEMU.
I have the flexible claw, phew, I thought I was obsolete.
Turns out I still am.
#10 Re: Courtesy light drama
Post by abowie » Fri Aug 16, 2024 8:40 am
I've bought one off EBay, predominately chosen by price.
It works well and does what I need.
dlgis
#11 Re: Courtesy light drama
Post by dlgis » Fri Aug 16, 2024 10:08 pm
I managed to get the cable out the hole with some garden wire, and fitted a new courtesy switch, but the light stays on all the time so I haven’t resolved my problem yet :roll:
My endoscope camera is a Depstech - from Amazon - there’s an app for viewing the image on ipads etc.
Darryl
#12 Re: Courtesy light drama
Post by Series1 Stu » Fri Aug 16, 2024 11:02 pm
dlgis wrote: ↑
The plunger on the switch is probably too short. Check that you have the correct switch and the double thickness striker plate on the door.
