Thanks all
Courtesy light drama
#1 Courtesy light drama
One of my courtesy light switches has broken in two and the wiring has dropped into the bodywork
What’s the best way to get at the wiring to poke it back out the courtesy switch hole? Bearing in mind I'd like to minimise disruption to my lovely new interior trim 🫤
Thanks all
Thanks all
Darryl
#2 Re: Courtesy light drama
You could try putting a bend in a piece of thin stiff wire and wiggle it around inside the hole hopefully you can catch the switch wiring in the hook and pull it back through
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
2016 Caddy van
#3 Re: Courtesy light drama
Hi Ian i did try that but no luck, i’ll give it another go tomorrow but no luck on the first attempt 🫤
Darryl
#4 Re: Courtesy light drama
Same thing happened to me, managed to fish it out with a piece of wire with a hook bend on the end.
Randall Botha
#5 Re: Courtesy light drama
No workshop should be without one of these:
https://www.ebay.co.uk/itm/314650556882 ... 6X69FV8XGN
1969 Series 2 FHC
1969 Series 2 FHC
Monkeyfinger
#6 Re: Courtesy light drama
Along with the above advise, I can recommend one of the very cheap endoscope camera attachments for use with a phone. Whilst the quality is not great, it would be good enough to see if your fishing technique is at all close to the prize. These start at around 8GBP on Ebay and on other sites. A myriad of uses around the home.
#7 Re: Courtesy light drama
Thanks John I've invested in one of those essential tools
and Richard a camera is a good plan, unfortunately mine broke a couple of months ago so I’ll order up another
and try further exploration with some bent wire in the meantime
Darryl
Monkeyfinger
#8 Re: Courtesy light drama
Can we approach you for some private medical work following a successful wire retrieval?
#9 Re: Courtesy light drama
Can anyone volunteer some experience with these cameras, purchase links or WHY ?
Happy to pay proper money for a 10 year lifespan if it’s possible to avoid effing TEMU.
I have the flexible claw, phew, I thought I was obsolete.
Turns out I still am.
#10 Re: Courtesy light drama
I've bought one off EBay, predominately chosen by price.
It works well and does what I need.
#11 Re: Courtesy light drama
I managed to get the cable out the hole with some garden wire, and fitted a new courtesy switch, but the light stays on all the time so I haven’t resolved my problem yet
My endoscope camera is a Depstech - from Amazon - there’s an app for viewing the image on ipads etc.
Darryl
#12 Re: Courtesy light drama
The plunger on the switch is probably too short. Check that you have the correct switch and the double thickness striker plate on the door.
