#1 2-post lift to remove/install engine from below
Posted: Fri Jul 24, 2015 3:26 am
Hi Gents,
I have been reading a lot on 2 vs 4 post lift for removing the engine from below. Obviously different views on which ways is best.
Getting my hands on a 4-post lift in Brazil wont cost less than ?5000. My plan is to use a 2-post.
I could acquire a ramp for 2-post, but removing the cross-member plate with the weight on front suspension will likely damage the threads from bolts holding the torsion bar setting plate.
The lifting approach described on the thread below seems straight forward. However, I am not this set up can be used to remove the engine without supporting the IRS.
viewtopic.php?p=20438
Has anyone made an bridge for the IRS to lift it using the post arms. I feel using a transmission cradle on the IRS would make things unpractical to lower/raise the car on the posts while compensating on the cradle.
I removed e-type engines at a friend's garage a few times using stands, not fun, seriously dangerous. Hence the reason to invest on a 2 post lift.
Sharing your thought will be appreciated!
Fred
Fred
