servo air hose bented
Polse7317
#1 servo air hose bented
Post by Polse7317 » Tue Jan 03, 2017 7:32 pm
I have a problem with the hose coming from the servo which has a curve so important that it collapses on itself and the air can't flow... Where can i find another hose with a 90° curve at one end ?
Mark Gordon
#2 Re: servo air hose bented
Post by Mark Gordon » Tue Jan 03, 2017 8:37 pm
You might try inserting a piece of 1/4 " copper tubing inside the hose and then gently bending it to the proper curve. Since there is no heavy flow of air through that tube a slight decrease in lumen size shouldn't make any difference and the tubing would keep the hose from collapsing. If that bodge doesn't work, you could just take it out and be back to where you are now.
Vegard
Norway
#3 Re: servo air hose bented
Post by Vegard » Tue Jan 03, 2017 8:54 pm
Never thought of that. What a great tip!! :drinkingcheers:
68 1.5 FHC, 65 4.2 FHC, 72 MGB GT, 6 Minis, 71 Escort1300GT, 65 BMW Neue Klasse, 62 Volvo P1800 and a 205 GTI
Simonpfhc
#4 Re: servo air hose bented
Post by Simonpfhc » Wed Jan 04, 2017 7:35 am
The best solution is to insert a spring of similar diameter to the inside of the tube. That way it can still freely bend and won't collapse.
Thanks.
62 3.8 FHC
91 Porsche 928GT
Polse7317
#5 Re: servo air hose bented
Post by Polse7317 » Wed Jan 04, 2017 12:36 pm
fine idea....! :thankyouyellow:
ralphr1780
#6 Re: servo air hose bented
Post by ralphr1780 » Wed Jan 04, 2017 1:02 pm
Yves, it should first be routed forward down to a guiding clip fixed on the pedal box, then back to the firewall.
There is nothing wrong with the hose itself. Try so see some pics in the factory fit thread which will illustrate well.
Ralph
'69 OTS + '62 OTS - Belgium
64etype
#7 Re: servo air hose bented
Post by 64etype » Thu Jan 05, 2017 12:15 am
Right....the forward loop and P-clip keep it from bending to a sharp angle. That said, AN type aircraft hose with a steel braided layer in the wall of the tubing, and a black nylon braiding on the outside not only won't collapse, but the exterior braided sleeve will be looking spiffy when the cotton sleeve is dirty and faded.
Eric
Hugo
#8 Re: servo air hose bented
Post by Hugo » Fri Jan 06, 2017 3:20 pm
[quote="lataud"]I have a problem with the hose coming from the servo which has a curve so important that it collapses on itself and the air can't flow... Where can i find another hose with a 90° curve at one end ?
Just looks too short to me?
