jeffbezz
Post
by jeffbezz » Wed Jun 10, 2020 5:46 pm
hi I have a jaguar etype not with its original engine , which seams for sure a jaguar engine as it has its block marked jaguar 4.2 .
its engine number starts 7E11 xxx -9 .
Found no recoders of 4.2 engines starting with 11 after the 7E , and clues please
Post
by christopher storey » Wed Jun 10, 2020 6:11 pm
7E is the correct prefix for a 4.2 , and there are engines which start 7E 11000 etc. It would be an engine made towards the end of S1 production, probably in 1967
The exception to this is 2+2 cars which had engines starting 7E 50001 as i recall
jeffbezz
Post
by jeffbezz » Wed Jun 10, 2020 6:39 pm
hi
I appreciate your reply, in fact date of production is November 1966
44DHR
Post
by 44DHR » Thu Jun 11, 2020 12:16 pm
Yes, 7E1001 onwards for 4.2 litre E Types. Firstly four digits then five digits from March 1967.
So 7E11xxx quite feasible.
My car was manufactured 3rd May 1967 and is one of the very last 60 Series 1 built. The engine number is 7E 13254-9.
Another check and cross reference is to see the casting date on the block. This date is cast into the block in a xx-xx-xx fashion within a cast rectangle near the sump joint and just in front of the dipstick. This should pre date the manufactured date of the car, unless a later block was fitted subsequently.
Cheers,
Dave Rose
1967 Series 1 4.2 FHC
Lizzy
Post
by Lizzy » Thu Aug 08, 2024 3:36 pm
Hi Jeff,
I just read your post on the engine,
I have the same problem, I should have engine 7E11043-9 in my car but I have 7E10711-9 (332 numbers before mine
you wouldn't by any chance have my engine and I yours?
kindly,
Kevin
Andyp_67E
Post
by Andyp_67E » Sat Aug 10, 2024 8:39 pm
44DHR wrote: ↑Thu Jun 11, 2020 12:16 pm
Just seen this post, my car 1E1817 has Engine number 7E 13154-9 exactly 100 before yours and built only 2 days before on 1st May 67.
Andy
1967 Series 1 4.2 OTS
Leicester, UK
