Clock Replacement Procedure
macdog
#1 Clock Replacement Procedure
Post by macdog » Sun Jul 21, 2024 12:28 pm
It is time to replace the clock in our 67 OTS. Being of considerable size and not that flexible I am wondering how in the world do I get up in there. Is it best to remove the tachometer? Any suggestions will be greatly appreciated.
tim wood
#2 Re: Clock Replacement Procedure
Post by tim wood » Sun Jul 21, 2024 5:34 pm
My thoughts are that removing the tach is the best way.
The clock needs to be slotted into position.
Tachometer can be removed either from the top by taking off the dash top or by removing the lower cover panel . This is a bit more fiddly getting to the tachometer fixings but less work.
I would take off the dash top.
Allrand
#3 Re: Clock Replacement Procedure
Post by Allrand » Mon Jul 22, 2024 7:04 am
:yeahthat:
Randall Botha
macdog
#4 !
Post by macdog » Tue Jul 23, 2024 5:52 pm
Wow, the dash top, I will look in that direction, never thought about removing that.
THANKS!
Iansparky
#5 Re: Clock Replacement Procedure
Post by Iansparky » Thu Jul 25, 2024 5:52 pm
There is a company in the UK called clocks 4 classics, he sells a kit to repair the original series 1 clock, it replaces the electrical contacts with a circuit board and the clock still ticks, its a bit fiddly to do but there is a lot of info and videos on the website. www.clocks4classics.com
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
caveman
#6 Re: Clock Replacement Procedure
Post by caveman » Fri Jul 26, 2024 5:52 am
:yeahthat:
Having converted my spare clock last year, it ticks away nicely and was simple enough to do. Having just completed a road trip it was nice to reference it rather than ignore it.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#7 Re: Clock Replacement Procedure
Post by DWW » Fri Jul 26, 2024 1:26 pm
Question, is the clock polarity sensitive? the reason I am asking is that my clock use to work until the car was converted to negative earth.
Allrand
#8 Re: Clock Replacement Procedure
Post by Allrand » Fri Jul 26, 2024 1:32 pm
Short answer - yes.
Randall Botha
#9 Re: Clock Replacement Procedure
Post by DWW » Fri Jul 26, 2024 5:39 pm
Lotus17racer
#10 Re: Clock Replacement Procedure
Post by Lotus17racer » Mon Aug 19, 2024 3:18 pm
I have had good experiences with clocks4classics……
PierreW
#11 Re: Clock Replacement Procedure
Post by PierreW » Sat Aug 24, 2024 6:09 am
I installed the clocks4classics modernization kit myself in the clock of my MK2 without any particular difficulty.
Jaguar MK2 1967 since 1980
Lotus Seven 1963 since 2015
XKE S1 1964 OTS since 2023
caveman
#12 Re: Clock Replacement Procedure
Post by caveman » Sat Aug 24, 2024 7:46 pm
:yeahthat:
:wavegreatbritain:
