Clock Replacement Procedure
#1 Clock Replacement Procedure
It is time to replace the clock in our 67 OTS. Being of considerable size and not that flexible I am wondering how in the world do I get up in there. Is it best to remove the tachometer? Any suggestions will be greatly appreciated.
#2 Re: Clock Replacement Procedure
My thoughts are that removing the tach is the best way.
The clock needs to be slotted into position.
Tachometer can be removed either from the top by taking off the dash top or by removing the lower cover panel . This is a bit more fiddly getting to the tachometer fixings but less work.
I would take off the dash top.
#3 Re: Clock Replacement Procedure
Randall Botha
#4 !
Wow, the dash top, I will look in that direction, never thought about removing that.tim wood wrote: ↑Sun Jul 21, 2024 5:34 pmMy thoughts are that removing the tach is the best way.
THANKS!
#5 Re: Clock Replacement Procedure
There is a company in the UK called clocks 4 classics, he sells a kit to repair the original series 1 clock, it replaces the electrical contacts with a circuit board and the clock still ticks, its a bit fiddly to do but there is a lot of info and videos on the website. www.clocks4classics.com
Ian
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
2016 Caddy van
#6 Re: Clock Replacement Procedure
Having converted my spare clock last year, it ticks away nicely and was simple enough to do. Having just completed a road trip it was nice to reference it rather than ignore it.
1965 S1 4.2 FHC (early)
#7 Re: Clock Replacement Procedure
Question, is the clock polarity sensitive? the reason I am asking is that my clock use to work until the car was converted to negative earth.
#8 Re: Clock Replacement Procedure
Short answer - yes.
Randall Botha
#9 Re: Clock Replacement Procedure
Lotus17racer
#10 Re: Clock Replacement Procedure
I have had good experiences with clocks4classics……
#11 Re: Clock Replacement Procedure
I installed the clocks4classics modernization kit myself in the clock of my MK2 without any particular difficulty.
Jaguar MK2 1967 since 1980
Lotus Seven 1963 since 2015
XKE S1 1964 OTS since 2023
#12 Re: Clock Replacement Procedure
