Series 2 aesthetics
#201 Re: Series 2 aesthetics
Hi Marek
I have your original led reversing lights. Are you able to swap out those for the new ones, or do you need to replace the whole unit?
#202 Re: Series 2 aesthetics
The new boards are a press fit into the clear Lotus bit of the rear lenses.
Since yours date from May 2016, I'm guessing you'd have to use a scalpel (or Dremel) to cut a hole in the back of the lenses to be able to remove the old LED board. Alternatively, delicately inserting a scalpel between the clear housing and the main body may pry the clear part free.
Later units are a simple swap over as they are unsealed.
#203 Re: Series 2 aesthetics
Are the LEDs "E" marked, like bulbs have to be? I have had a ticking off from the authorities for the reversing lights on the MOT test
-Mark
#204 Re: Series 2 aesthetics
The MGB square lights used by Jaguar will have had markings on them. The clear inserts that make a standard s2 or s3 rear light into a "Lotus" light never had any markings on them. All I have done is change the festoon bulb for a brighter array of LEDs, neither of which ever had markings.
The markings on the s2 or s3 main orange/red rear housings are exactly as before.
Jeff Cecil
#205 Re: Series 2 aesthetics
#206 Re: Series 2 aesthetics
Jeff, those lights look interesting, tell us more, please
#207 Re: Series 2 aesthetics
MGB rears.....Steve
Jeff Cecil
#208 Re: Series 2 aesthetics
#209 Re: Series 2 aesthetics
Here's a couple of pics of Marek's LED reverse lights in action. White for reverse, red for brakes. Very cool!
- Attachments
- ec00864b028048a0394977f7fe40b61d761d3b84_2_666x500.jpeg (138.8 KiB) Viewed 21012 times
- e03f0d196977e2805f691e541b7e77aa6263890d_2_666x500.jpeg (164.12 KiB) Viewed 21012 times
Bob t
#210 Re: Series 2 aesthetics
Jeff Cecil
#211 Re: Series 2 aesthetics
Jeff Cecil
#212 Re: Series 2 aesthetics
#213 Re: Series 2 aesthetics
Ok.....dont like the colour of the rear numberplate....dosnt really go with the paintwork.....and dosnt look straight
#214 Re: Series 2 aesthetics
And the sky is way too blue, it needs clouds.
Jeff Cecil
#215 Re: Series 2 aesthetics
Jeff Cecil
#216 Re: Series 2 aesthetics
#217 Re: Series 2 aesthetics
If you're looking for comments on atheistics, it's got to be about the super wide Series 2 rubber bumper to body seal. Far from worrying if the number plate is straight, change that rubber strip for the Series 1 narrow one today.
1969 Series 2 FHC
1969 Series 2 FHC
#218 Re: Series 2 aesthetics
Hi Jeff. Trying to get in touch with you..I’m in SC. Could you email me.
Enoreeriver at gmail. Thanks! Anthony
Jeff Cecil
#219 Re: Series 2 aesthetics
#220 Re: Series 2 aesthetics
Jeff, do you have the information on how you did that, please?
S2 4.2 FHC
Ford F100 pickup
KTM 525 XC
BMW R1300RS
BMW R100rt
"You only live once, but if you do it right, once is enough..."
Ford F100 pickup
KTM 525 XC
BMW R1300RS
BMW R100rt
