#1 Valve timing gauge
Posted: Wed Mar 11, 2020 3:12 pm
by japomero
Looking for someone who could provide a photo of the valve timing gauge with a ruler in the frame.
Thanks for the help
Jim
#2 Re: Valve timing gauge
Posted: Wed Mar 11, 2020 3:41 pm
Hi Jim.... sorry dont recognise the term..valve timing guage....what us it......Steve
#3 Re: Valve timing gauge
Posted: Wed Mar 11, 2020 3:45 pm
by japomero
Hi Jim.... sorry dont recognise the term..valve timing gauge....what us it......Steve
Thanks Steve
It is a flat steel gauge that fits over the end of the camshaft on engine assembly that holds the camshaft in position while the #6 piston is at TDC.
#4 Re: Valve timing gauge
Posted: Wed Mar 11, 2020 4:11 pm
Camshaft setting/Timing tool
#5 Re: Valve timing gauge
Posted: Wed Mar 11, 2020 6:12 pm
by japomero
Perfect.
Thanks a bunch.
Jim
#6 Re: Valve timing gauge
Posted: Wed Mar 11, 2020 8:15 pm
by Gfhug
They are readily available to buy for about £10 ($15) so no reason to make an imperfect one from guessing dimensions from a photo if that is your plan
#7 Re: Valve timing gauge
Posted: Thu Mar 12, 2020 2:33 pm
by japomero
Great information. Where are they available from?
Jim
#8 Re: Valve timing gauge
Posted: Thu Mar 12, 2020 3:09 pm
Jim...google is your friend...just search Jag cam setting tool
#9 Re: Valve timing gauge
Posted: Fri Mar 13, 2020 9:46 pm
by Lost Horizon
And, to round out the thread, here it is in action...
#10 Re: Valve timing gauge
Posted: Sat Mar 14, 2020 11:33 pm
by keithmac
Try Browns Lane Jaguar. Canadian E-Type specialist and parts supplier. He likely has them in stock.
http://brownslane.com/
Keith
#11 Re: Valve timing gauge
Posted: Sun Mar 15, 2020 3:29 pm
by japomero
Thanks all. The photo was great. Have the drawing done.
Easy cut from 3/16 plate.
Jim
#12 Re: Valve timing gauge
Posted: Tue Mar 17, 2020 10:36 am
by malcolm
Still wouldn't do that Jim. It may not look it, but the measurements are very sensitive. Little bit out, and engine won't be perfect. Just get one sent from UK if you can't source it.
