I have finally acquired a radiator header tank for my car which is a right hand drive UK car and never had one in my ownership. I know that on RHD cars the tank is spaced off the bulkhead to clear the accelerator linkage but I don't have any of the mounting hardware and I have to turn up some spacers on my lathe. (I do have the correct bracket). Please could someone with a RHD car measure how long the spacers are and let me know.
Eric
Header Tank Question
Eric Capron
Topic author - Posts: 41
Hi Eric.....Iv just purchased a S2 2+2 ( my first Jag) & the header tank is on the passenger side away from the throttle linkage so I assume that you have the FHC...However I see that you are based in Shropshire...Im near Leominster & Ludlow at the weekends .If your interested in meeting up sometime (or anyone else in the area) it would be good to talk about the cars...Steve Tel 0797 495 2877
Eric Capron
Hi Steve,
Thanks for your response. I have an OTS S2 and I am confused. I thought that the tank was fitted on the same side as the steering wheel and did not depend on the body style. The reason I believed this is because the factory parts manual lists different setscrews for the bracket mounting for RHD & LHD cars without differentiating body style. The setscrews for the RHD cars are 1/2" longer than for the LHD cars and RHD cars additionally have three distances pieces (BD.18597/1) to space the bracket off the bulkhead.
However, Philip Porter's book shows all three body styles for S2 in RHD; the FHC & OTS have the tank on the right whereas the 2+2 has it on the left as it is on your car. This is at variance with the parts manual but this happens sometimes. It may be that the bulkhead is different on the 2+2 due to the extended length of the vehicle.
On my car the windscreen washer bottle is mounted on the left hand side of the bulkhead so I assume that it is in a diffent place on yours.
By the way, since no one has come up with an answer to the question I have experimented and found that about 5/8" for the spacers works quite well.
Finally, I live in Church Stretton, not far from you. You might also be interested in knowing that the JEC Shropshire and Welsh Borders region meets in Shrewsbury on the second Tuesday of each month ie tomorrow!
Eric
Eric
Eric,
I suspect you've got it sorted by now but I've measured the spacers and the dimensions are:
length = 19/32" (so 5/8" was close)
external diam = 3/8"
internal diam = 7/32"
Chris
Chris
Eric Capron
Chris,
Thank you for the dimensions. Much appreciated. The tank is fitted and doesn't foul on anything but I will make some more spacers because I am way off with the external diameter (too thin).
Before fitting the expansion tank I was putting in water every time I drove the car but now I don't have to. That's one job out of the way but there is always something to fix. Why are the windows so stiff; why does the alternator seem to overcharge; why is there so much wind noise with the hood up and many more? The thrills of driving a 40 year old car!
Eric
Eric
