Vehicle ID tags location
#1 Vehicle ID tags location
Gents,
I need to attach these two tags to my S2. The PO had bagged and tagged them, but I could use a good picture showing exactly where and how they were attached.
The bottom one goes somewhere on the rear bulkhead (behind the license plate?) the top one I think goes on the driver side door frame?
Also, as you can see, one is pretty deteriorated. Can replacements be purchased? :edit: I saw a source mentioned of CMC. Dont know how to reach them. Any clues?
Thanks much for any help you can provide.
Bob t
Bob t
Bob t
LHD '69 OTS. (Former) basket case
#2 Re: Vehicle ID tags location
Bob,
The top one is for behind the windshield, on the a-post. (my guess is only the US had those, on the left on lhd cars. Could somebody please confirm that?)
The bottom one is the body number tag, it is riveted on the body from the rear, behind the tag, on the rh side. You should be able to locate
The original rivet holes?
Martin
Martin
Martin Scherz
Late S2 1970 OTS US LHD
#3 Re: Vehicle ID tags location
Nickleback
#4 Re: Vehicle ID tags location
Correct, the top one is on the A post about half way down the inside, mine is on the left hand side as mine was a LHD XKE S2.nefematic wrote:Bob,
Mike,
1970 S2 FHC 2R28165
1970 S2 FHC 2R28165
#5 Re: Vehicle ID tags location
Thank you, gentlemen.
Addendum: I will bring some closure to my own questions by posting this pic of the body tag mounted on a car
- Attachments
- E type rear 003_zpshj9utetr.jpg (158.66 KiB) Viewed 6464 times
Bob t
#6 Re: Vehicle ID tags location
were you able to get new tags made
I restored my 69 s2 15 years ago and replaced the rear tub body number got thrown out then
and would like replace it I have my heritage cert for proof all numers match
regards tony
regards tony
#7 Re: Vehicle ID tags location
Did not pursue this, but filed it for future reference. Hopefully someone who has done it will post.dh100m wrote:were you able to get new tags made
Bob t
Steve Marshall
#8 Re: Vehicle ID tags location
That looks hauntingly familiar! Sadly I think it fell off when the shell was dipped to strip and derust it.Tbob wrote:Thank you, gentlemen.
Last edited by Steve Marshall on Thu Jan 26, 2017 9:41 am, edited 1 time in total.
#9 Re: Vehicle ID tags location
Is there a supplier for the windscreen tags?
-Mark
