42south wrote: ↑Thu Jun 28, 2018 11:27 pm
Before you go and spend money on another fan, check out
http://www.coolcatcorp.com/V12Fan/V12Fans.html
for an innovative solution using modern fan motors(VW) and a modern replacement for the otter switch. The owner Mike is on this forum and his service is second to none.
http://www.coolcatcorp.com/Merchant5/me ... e=Cooling3
I did this on my S3 and feel a lot happier with the cooling setup.
I would also replace the old tin can relay with a modern Bosch one, much more reliable.
Then finally use one of the dash switches in the manner that John suggests, as an override to the Otter switch. I turn mine on any time I stop in traffic in warm weather, before the Otter switch calls for them on, gives peace of mind.
Happy motoring
Dear Mark,
i have just finished to rebuilt my series 3 and even if i have not driven it so much, the temperature is currently pretty high in France (32 - 35 degres C) and i get conscious when i see the temp moving up above the NORMAL range. Thi usually happen when i stop at traffic light or drive through villages at low speed and/or stop a lot. last week end i have installed a switch to activate the fans earlier and it seem that it helps a lot.
On the 22sd of June i'll attend to a special classic event through Paris and it ll be almost only satrt and stop every 10 meters and i'm getting concerned.
I'm therefore considering fitting the VW fan mentionned in the first link. I found them easily on the net(around 30 euros each).
I nevertheless need some confirmations from your experience:
1) you fitted them in lieu of the originla one without any modification?
2) You wired from the original wiring the low speed terminal for both fans?
3) You have not changed the relay?
4) do you confirm that even at low speed the level or air blown is as gogo as the orgiginal?
5) For the high speed one you have a dedicated wire with a swith with a 50 amp fuse?
Therefore the interest of this installation is really to take benefit of the extra flow activated by the switch?
Many thanks in advance
regards
Jérôme
