Engine breather hose.
lee-type
#1 Engine breather hose.
Post by lee-type » Fri Jun 29, 2018 4:37 pm
Good evening guys
Does anyone know where i can get some of this aluminium hose form that is being used in the photo below?
I have looked all over the internet but i just can seem to find any the diameter.
Cheers.
Lee
S1 4.2 OTS
#2 Re: Engine breather hose.
Post by mgcjag » Fri Jun 29, 2018 5:13 pm
Hi ...SNGB sell it....i am useing...it....try a search on their site for breather hose.. Steve
There you go ...took 2 mins.. https://www.sngbarratt.com/uk/#!/Englis ... 10d80fe784
lee-type
#3 Re: Engine breather hose.
Post by lee-type » Fri Jun 29, 2018 5:20 pm
Tanks!
Im going to make a vintage style breather can so i want some for the diameter.
What does your breather hose go in to?
Cheers.
Lee
S1 4.2 OTS
#4 Re: Engine breather hose.
Post by Heuer » Fri Jun 29, 2018 5:29 pm
Mine goes from the special CMC dual breather casting and both hoses vent the road via.the under-tray. Ideally and responsibly you should vent to a catcher tank as shown in your photo - big ally cylinder. The tanks are available from places like Rob Beers or maybe Demon Tweaks.
#5 Re: Engine breather hose.
Post by mgcjag » Fri Jun 29, 2018 6:53 pm
As above...mine just vents under the car....but im doing a new build and will vent to a catch tank..Steve
lee-type
#6 Re: Engine breather hose.
Post by lee-type » Fri Jun 29, 2018 6:57 pm
Have you seen a style of catch can that you like? most of the ones i have seen are cheep looking Chinese red n blue looking things.
Cheers for the info Lee.
Lee
S1 4.2 OTS
#7 Re: Engine breather hose.
Post by mgcjag » Fri Jun 29, 2018 8:24 pm
Just search on ebay..... for aluminium oil catch tank......plenty there.. or look at car builder solutions .. Steve
norman m. macleod
#8 Re: Engine breather hose.
Post by norman m. macleod » Fri Jun 29, 2018 11:02 pm
Hi All,
I have fitted a Mann+Hummell Provent 200 Catchcan/Separator Kit to my Series 1 4.2 2+2. These are around the AUD$300:00 mark down here, and provide what I consider to be a most satisfactory solution to the venting problem. The unit separates the oil from the vent fumes, and incorporates a (periodic) drain tap, "Dried" gases I then directed to the inlet manifold. Internal filter/separator elements in the Provent unit are replaceable. For various connections (front breather plus I have extra breathers to cam covers.......) I used the aluminium mini-concertina breather hose that SNG list for the XK series cars (C2485/1).
I trust this may assist any Forum members looking for a responsible solution.......
Kind regards,
Norman.
P.S. BTW, beware suspiciously cheap copies on the internet, made in PRC......
1967 S1 2+2
lee-type
#9 Re: Engine breather hose.
Post by lee-type » Sat Jun 30, 2018 7:35 am
Hi All,
Kind regards,
Norman.
Cheers Norman
Im sure you system works really good but i am looking for a catch can that is more period correct.
I have lots of photos of catch cans from C-Types,D-Types and E-Types Lightweights so i think i am going to fabricate my own.
Lee
S1 4.2 OTS
#10 Re: Engine breather hose.
Post by Gfhug » Sat Jun 30, 2018 9:55 am
Lee, is it really necessary to keep quoting previous posts? It takes up valuable space and if you do need to quote it can be cut down to just the relevant sentence rather than a complete, long post.
lee-type
#11 Re: Engine breather hose.
Post by lee-type » Sat Jun 30, 2018 10:22 am
Yes it is necessary.
Lee
S1 4.2 OTS
#12 Re: Engine breather hose.
Post by Heuer » Sat Jun 30, 2018 10:42 am
No it is not. Try keeping in tune with the community and their wishes. Most of these guys have been here longer than you and they are hugely knowledgeable so if you want their help go with the flow.
lee-type
#13 Re: Engine breather hose.
Post by lee-type » Sat Jun 30, 2018 10:46 am
I do not understand use of quote. I was under the impression that is how you reply to someone.
When is it appropriate to use quotes?
Lee
S1 4.2 OTS
#14 Re: Engine breather hose.
Post by mgcjag » Sat Jun 30, 2018 10:57 am
Hi Lee...you last post is fine...nothing quoted.....also worth trying to put your name and car model in the signature area......use quotes when you think its needed....but you dont need to quote the whole post,..all the best.. Steve
#15 Re: Engine breather hose.
Post by Heuer » Sat Jun 30, 2018 4:45 pm
You normally use the quote function if you are answering a post that is on a different page or many posts earlier. It could also be used if you want to answer a specific question embedded in a long post but to do that you use the quote function and then edit out all the text that is not required.
lee-type
#16 Re: Engine breather hose.
Post by lee-type » Sat Jun 30, 2018 5:04 pm
Ok guys taken in sorry for and miss use and confusion caused!
Hope you all have a good weekend!
Lee
Lee
S1 4.2 OTS
MarkRado
Austria
#17 Re: Engine breather hose.
Post by MarkRado » Mon Jul 02, 2018 7:05 am
Is the breather hose also available by the metre? Would be convenient for more frequent replacement, sinde it gets dented quite easily.
1963 OTS 880436
#18 Re: Engine breather hose.
Post by mgcjag » Mon Jul 02, 2018 7:31 am
Hi Mark...the link i posted above for the hose at SNG is for a metre..Steve
MarkRado
Austria
#19 Re: Engine breather hose.
Post by MarkRado » Mon Jul 02, 2018 5:21 pm
Steve, thank you, I ordered from them last time, I thought it to be a bit expensive and would like to buy a roll of say three metres - for that money :wink:
1963 OTS 880436
#20 Re: Engine breather hose.
Post by mgcjag » Mon Jul 02, 2018 5:52 pm
Hi Mark..yes so would i :bigrin: :bigrin:
