I went out for a Drive last night some concernes as follows:
As usual about 20 mins to get a 40 psi oil pressure & 70 water temp reading.
Some Issues & concerns
A) When switching on Headlamps loss of Engine Power & bad response
B)On highway engine becomes only between 1/4 & Half on water temp with a lower Oil pressure & poor engine peformance
For item A I wandering if its the battery or Alternator or something else as I am quite a Novice on the car.
For item B I dont quite understand as outside temp about 17c.
Anyway I limped home without headlights but with concern
Maybe I should check the battery charge or see if its the proper one
Should we test whats coming out of the Alternator ?
