Earth wires connection
david muir
Scotland
#1 Earth wires connection
Post by david muir » Fri Aug 31, 2018 9:24 am
Hi, Just tidying up starter solenoid and battery cables on my 3.8. There were 2 earth wires connected to the mounting screw on the solenoid-is that where they should be?
1964 3.8 FHC
Philk
#2 Re: Earth wires connection
Post by Philk » Fri Aug 31, 2018 12:23 pm
Has the car been converted to negative earth? It would be useful to know this.
1964 S1 3.8 OTS
david muir
Scotland
#3 Re: Earth wires connection
Post by david muir » Fri Aug 31, 2018 5:03 pm
Yes Phil, it is negative earth. I think I remember changing it when I fitted an alternator!
1964 3.8 FHC
david muir
Scotland
#4 Re: Earth wires connection
Post by david muir » Fri Aug 31, 2018 5:12 pm
Okay folks, found a picture in the 3.8 Factory Fit section which shows earth wires attached to the starter solenoid mount screws. Answered my own question-relax!
1964 3.8 FHC
#5 Re: Earth wires connection
Post by Series1 Stu » Fri Aug 31, 2018 11:17 pm
I don't understand why that would make a difference to the answer of the question asked. :scratchheadyellow:
#6 Re: Earth wires connection
Post by abowie » Sat Sep 01, 2018 2:46 am
I agree that it shouldn't.
There are 2 ways to wire this solenoid depending on whether you actually want it to work or not.
Sometimes people bypass it so that the only solenoid that works is the one on the starter. A simple matter of moving wires from one side of the switch to the other.
