I was working single handed lay in a single garage. The problem is, with the suspension at full droop, the radius arm is too short to reach over the post on the car. The cage needs to be pulled forward to allow the bush to line up. The solution... One large ratchet strap, hooked between the front wishbone and the rear hub. A couple of clicks on the ratchet, and everything lined up. The radius arm can then be lifted up with a trolley jack and the bolt refitted. In my case, getting one side on was sufficient to allow the other side to line up without the ratchet strap.
