High Beam problem
dale bowman
#1 High Beam problem
Post by dale bowman » Fri Sep 21, 2018 4:47 pm
Only my second post and still getting used to new ownership (1 week and counting) so this may just be me.
Turned my lights on, side and head are all fine. Flasher works no problem but when I flick the headlight switch on the right side of the dash it turns the heads off and I don't have full beam. I am correct in thinking this switch is for full beam. If so, is this a simple problem to fix …. I'm hoping someone has experienced something similar
Cheers Dale
1964 series 1 3.8 fhc
There are three types of people in this world.
Those who can count and those who can't.
Turnip
#2 Re: High Beam problem
Post by Turnip » Fri Sep 21, 2018 8:15 pm
Hi Dale.
You're right in that the R/H side dash switch is the high/low beam selector (RHD).
As you say that the flasher works (i.e. the full beam flashes) that suggests there's a break somewhere between the high/low switch and fuse No.1 . Possibly the cable has become disconnected from the switch, or the switch is faulty.
The switch is relatively easy to extract from the dash, once you have the relevant under-dash panel removed.
1965 Series 1 4.2 FHC
Geoff Allam
#3 Re: High Beam problem
Post by Geoff Allam » Sat Sep 22, 2018 2:35 am
Remove the switch and jumper the wires to check if the problem is in the wiring or in the switch. In both my e types I have had what you describe happen and both times it was a failure in the switch. The switch can be taken apart and repaired quite easily or replacements are available.
Geoff Allam
dale bowman
#4 Re: High Beam problem
Post by dale bowman » Sat Sep 22, 2018 7:03 am
That's great …. thanks Gents. A few small jobs to look at this weekend :-)
