3.8 Choke Cable, Clamp For Outer At Lever
glennglenn
Topic author - Posts: 18
#1 3.8 Choke Cable, Clamp For Outer At Lever
Is there a clamp to suport the outer cover in the cockpit by the choke lever? Mine seems to be too lose when putting choke back to cold normal running, the chokes are not fully releasing.Also what’s the correct route for the cable, I know this has been covered before but the images have been erased. Thanks!
Fasthound1963OTS
#2 Re: 3.8 Choke Cable, Clamp For Outer At Lever
This might help. I finally routed mine similar to the photos shown near the end of the thread.
https://forums.jag-lovers.com/t/choke-c ... /352541/11
1963 3.8L S1 OTS - apparently resurrected from multiple sources because not a single number matches
#3 Re: 3.8 Choke Cable, Clamp For Outer At Lever
http://forum.etypeuk.com/viewtopic.php? ... ram#p80556
The choke cables are routed via the hole labelled ??? on the bottom line of the diagram.
-Mark
