S2 matching numbers block & cylinder head
Wilder
#1 S2 matching numbers block & cylinder head
Post by Wilder » Tue Jan 08, 2019 7:32 pm
I believe at some point during S2 production, that jaguar stopped stamping the engine number into the cylinder head.
Does anyone know when this happened?
I cannot find the number on my car which is an OTS from 10/69
Any help or photos where to look would be appreciated.
:bigrin:
Jonathan K
#2 Re: S2 matching numbers block & cylinder head
Post by PeterCrespin » Thu Jan 10, 2019 2:04 am
I think it was during late 67 that they switched to bare aluminium un-numbered heads for the 68 models. The engine number stayed above the oil filter for a bit longer before migrating to the left upper bell housing flange.
sk99
Sweden
#3 Re: S2 matching numbers block & cylinder head
Post by sk99 » Thu Jan 10, 2019 10:01 am
My FHC built in october -67, has no stamped engine number on the head.
1967 FHC LHD
1966 OTS RHD
#4 Re: S2 matching numbers block & cylinder head
Post by Heuer » Thu Jan 10, 2019 1:27 pm
There is no published date when they stopped stamping the heads. I don't believe it necessarily coincided with a change in part number or head colour though.
Wilder
#5 Re: S2 matching numbers block & cylinder head
Post by Wilder » Fri Jan 11, 2019 5:10 pm
Well here is one to file for future reference. I think you all may find it really interesting.
Dear Jonathan
Thank you for your enquiry regarding:
Whether a USA specification Jaguar E type S2 (4.2) from October 1969 would have left the factory with the engine number stamped into the cylinder head.
Thank you for confirming that your vehicle is a S2 E-type and supplying the chassis number: 1R 10***; and engine number: 7R 70**-9.
I can confirm the following. During Series 2 E-type production, from engine numbers 7R 6306 and 7R 38106 the location of the stamped in engine number was moved to the rear of the left-hand side of the block, on the flange of the bell-housing, and cylinder head was no longer stamped with the engine number.
Jaguar Heritage Trust Archive
Jonathan K
johnetype
#6 Re: S2 matching numbers block & cylinder head
Post by johnetype » Sun Jan 13, 2019 8:05 pm
Yes but that doesn't mean they hadn't stopped stamping the number onto the cylinder head before then.
I believe 7R6306 was produced around August '69 (Porter).
1969 Series 2 FHC
Wilder
#7 Re: S2 matching numbers block & cylinder head
Post by Wilder » Sun Jan 13, 2019 8:53 pm
My car was built Oct 1969 with the engine number on the bellhousing flange, and so am in the clear.. :bigrin:
Jonathan K
#8 Re: S2 matching numbers block & cylinder head
Post by mgcjag » Tue Jan 15, 2019 12:22 pm
Just to add an Aug 1969 service bulletin (in knowledge base) confirms engine number moved to left side of engine from engine No 7R6306 & 7R38106......no mention on number on head.......Steve
