The glass bowl/ filter was designed to take fuel through the bowl lid and down the center of the filter into the glass bowl....particals would be left in the bowl then filtered through the element towards the carbs..early cars had a wire gauze type element followed by a donut shaped stone type then a paper element...all of these allowed the "dirty"fuel to pass directly into the bowl befor being filtered....the advantage being a quick look into the bowl for debris...............As far as im aware the only filter widely available is C28080...a paper element but with a metal base and a spring to hold it in the bowl.....this now works in reverse....fuel comes into the filter but because of the metal base cannot pass uninterupted into the bowl...instead it passes through the element leaving any debris inside the filter unsean.....clean fuel goes into the bowl and to the carbs....
Useing this canister type filter therefore can cause a problem by being blocked with no visable sign by looking into the glass bowl.......thanks for reading and over to you.....
Edit.....was the canister type used on later cars and the i/p..o/p reversed to the glass bowl so that unfiltered fuel could be seen in through the glass......Steve
Stone/fibre element
