Lucas screenjet cage rubber
ollieoscarsid
#1 Lucas screenjet cage rubber
Post by ollieoscarsid » Wed Feb 20, 2019 11:36 am
Morning all, does anyone know if you can get hold of the rubber tubing that goes round the top and underneath the washer bottle cage on an early series 1. Ta.
1963 S1 opalescent silver blue
#2 Re: Lucas screenjet cage rubber
Post by rswaffie » Wed Feb 20, 2019 12:25 pm
I had the same requirement last year, but couldn’t find any oem for it, so I improvised with ‘u’ profile neoprene edge trim. Another forum member asked me what I used and I sent him what I had left over (Robbiee), so I cant help you out with a sample I’m afraid.
JerryL770
#3 Re: Lucas screenjet cage rubber
Post by JerryL770 » Wed Feb 20, 2019 5:08 pm
Woolies Trim or Holden are likely to have this type of rubber.
https://www.woolies-trim.co.uk/
https://www.holden.co.uk/default.asp
Jerome Lunt
AshM
#4 Re: Lucas screenjet cage rubber
Post by AshM » Thu Feb 21, 2019 12:50 pm
Neat job Richard - looks great.
For some perverse reason I really enjoy restoring the ancillary items such as this. Very satisfying work.
Series 2 FHC 1970
1R 20607
#5 Re: Lucas screenjet cage rubber
Post by rswaffie » Thu Feb 21, 2019 1:03 pm
Thanks. I had to do a fair bit of work on the pump impeller assembly as well. Hard water had mad the plastic brittle and the hose connector at the output had crumbled away. You can’t get replacements the look the same so I had to enlarge the hole from the impeller, glue in a small bore s/steel tube and connect it to a new hose.
Luckily, the pump itself just needed cleaning and oiling.
ollieoscarsid
#6 Re: Lucas screenjet cage rubber
Post by ollieoscarsid » Sun Feb 24, 2019 7:56 pm
Thanks Richard, looks great. I’ll try woolies and if no luck may go the same route as you. Cheers. Chris.
