Where to mount rotisserie on rear of S3
#1 Where to mount rotisserie on rear of S3
I have managed to get hold of a rotisserie to enable me to work on my S3. I am looking to make some brackets to get the rotisserie to fit my car but need to know if any of you good folks have any pictures of where to mount it to the back end? I have had a few suggestions, but believe a picture tells a thousand words.
#2 Re: Where to mount rotisserie on rear of S3
#3 Re: Where to mount rotisserie on rear of S3
#4 Re: Where to mount rotisserie on rear of S3
Ha Ha good one Malcolm.
Wow James, that's a feat of engineering - you must need a degree in architecture to build that?
Not sure my amateur welding skills can stretch to something as complicated as that.
#5 Re: Where to mount rotisserie on rear of S3
Hi.....worth looking here.....possibly cheaper than making your own...also call to see how they mount...Steve https://www.rolloverjigs.com/product/jaguar-e-type-jig/
#6 Re: Where to mount rotisserie on rear of S3
Hi Steve,
Thanks for the link. However I already have the rotisserie. I am just having difficulty seeing where to mount it onto the rear end of the car.
#7 Re: Where to mount rotisserie on rear of S3
Hi Davie
I'm assuming the rear end of an S3 is not a lot different to an S2? If this is the case then these pics of the rear rotisserie mounting on my S2 might help?
ATB
Andy
ATB
Andy
Andy
1970 S2 FHC
1965 SB Corvette Ragtop
1970 S2 FHC
#8 Re: Where to mount rotisserie on rear of S3
Hi Andy,
Those pics are really helpful.
Thanks very much.
Thanks very much.
#9 Re: Where to mount rotisserie on rear of S3
Hi Dave,
This is how I made the one on mine. With the front I utilised the front Picture frame as the frames were rusted. and the rear I attached to the Rear to the Middle bar mounts and drilled 2 extra holes to mount the lower bracket.
Cheers John
Cheers John
Restoring 73 Series 3 2+2
