Soft top pictures
Grant
#1 Soft top pictures
Post by Grant » Tue Apr 09, 2019 6:20 pm
Hi All
I’m just trying to recover my soft top would someone be kind enough to take and post a picture of theirs with the roof up ?
I’m trying to line up the side of the roof with the top of the frame above the side window if that makes sense.
All the ones I can find on line are taken from an angle , can I have one square on please.
Many thanks in advance
Grant .
Series 2 OTS LHD
tonyabacus
#2 Re: Soft top pictures
Post by tonyabacus » Sun Apr 21, 2019 2:00 pm
Hi Grant
Common problem I think and not always as straight forward as first appears. If you get access to the following book it has a good description of what is involved together with part numbers of shims needed. It is not a quick task but requires that the hood has been fitted and shimmed correctly to begin with, but this book (sometimes available in the local library) will provide most of the information required to get the gaps right. There are other books but this has proved invaluable to me. You can see some of its content on the Net if you do a little searching, part of which I found was on the soft top itself.
Hope it goes well
Tony
Title:-E-Type Jaguar Restoration Manual
Author:-Barzilay, David
Publisher:-The Crowood Press UK
ISBN13:-9781785002847
lopena
#3 Re: Soft top pictures
Post by lopena » Mon Apr 22, 2019 3:59 pm
Grant:
I'll be happy to send you photos of the soft top on my '64 E-type...just tell me exactly what you are looking for...exterior shots, interior shots, etc.
Alan
New Jersey
Grant
#4 Re: Soft top pictures
Post by Grant » Mon Apr 22, 2019 7:22 pm
Hi Alan and Tony
Thank you both for your replies but as this I a major part that everyone can see I’ve decided this is a job best left to the professionals !
Thanks again
Grant
Series 2 OTS LHD
lopena
#5 Re: Soft top pictures
Post by lopena » Mon Apr 22, 2019 8:16 pm
Smart move, Grant.
