Post
by jagwit » Mon May 13, 2019 8:24 am
Dear Michel
With my previous posting, I only looked at Emerald from a technical viewpoint. This morning, I looked at its price and was shocked to see how expensive it was GBP714 (Euro827) !! By comparison, a Megasquirt-2 will be about USD350 (Euro312) - including a few extra bits and pieces.
MS-2 will not have any knock-on effects like upgrading injectors (and fuel rail) or the additional peak and hold electronics which makes the Emerald solution even more expensive.
Michel, you were on a good path planning to use the original ECU. With all my EFI conversions, I always found that getting EFI fuel supply sorted (never mind EFI itself) was a substantial challenge in itself. I now am of opinion that you made an error purchasing the Emerald.
I would encourage you to return the Emerald and either:
1) Continue with the OEM ECU and ignition (which will be challenging already);
2) Or go the MS-2 route – but using the distributor so that you can use a single ignition output on the MS-2, again to keep things “simple”.
If you do go the MS-2 route, I would further suggest that you do the EFI conversion in phases:
1) first get the car running again in standard configuration – with carbs and dissy – just to get it running again;
2) Then, implement MS-2, running off the crank trigger but controlling only ignition with a single coil output, a very low impedance coil (or using the original dual coils from an HE) and the distributor but still running on carbs; Ignition only will already present a massive learning curve but at least you will not be faced with issues on BOTH ignition and fuelling sides. Then, once you have ignition under control, you can move to fuelling.
3) Last phase would be to implement EFI, ; This means you can use the maps I (or Marek ??) can provide with support from us both (I presume) and the MS forum if need be.
Michel, allow me to add two more thoughts :
IMHO, the V12 E-type’s most urgent upgrade is from the outdated OPUS ignition system to a modern ignition system. A mapped ignition system is by far, 1st prize. Second to that is an overdrive transmission (again, my opinion!!) – NOT EFI.
I did the an EFI conversion on my 1st E-type (the OTS). At this time I did not understand carbs and did not care to either. After I had done that, the car was begging for an overdrive (and it had a 3.07 diff).
With my current E-Type, running Lumenition ignition (with vacuum advance) and VERY well tuned ZS-carbs (now that I understand carbs better), I again am faced with a car begging for overdrive because it is running so well that I am not at all motivated to do the EFI thing again.
Recently I “upgraded” the diff from 3.31 to 2.88 and this has improved matters HUGELY but even so, it can STILL do with an overdrive transmission.
All the above is intended to allow you a rethink of your project. Whilst our opinions may vary, I hope that the underlying reasons of those opinions may equip you with an understanding that will allow you to formulate a solution that will WORK for YOU.
Best Regards
Philip
