C17544 special washer under air intake box wing nuts
ysmalkie
Poland
#1 C17544 special washer under air intake box wing nuts
Post by ysmalkie » Sat Apr 27, 2019 3:33 pm
Would anyone have the original C17544 washer for air intake box wing nuts?
It's not a standard one, so it could be wider, thicker or might have special finish..
Would anyone help?
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
#2 Re: C17544 special washer under air intake box wing nuts
Post by Heuer » Sat Apr 27, 2019 5:36 pm
Hi Tadek
Don't have an original one but maybe this closeup will allow you to see what it was like:
It is a 'repair' washer (also known as a mudguard, fender or penny washer) as against a 'plain' washer and having a particularly large outside diameter to provide a greater area for distributing the load; useful in securing something a traditional nut and washer would pull through.
Outer diameter of 1" and 5/16" centre, 1/16" thick and originally cadmium plated. Generally available although usually in metric equivalents of 25mm x M8 x 1.65mm and zinc plated. I use a spring washer as well because the wing nuts can come undone and the original size is expensive to replace at £7 each. Spring washer can't be seen when in place.
You can buy them here amongst other places: http://www.racetorations.co.uk/fastener ... washer-p33
I will add an update to Factory Fit to cover them: http://forum.etypeuk.com/viewtopic.php?p=35355#p35355
Durango2k
#3 Re: C17544 special washer under air intake box wing nuts
Post by Durango2k » Sat Apr 27, 2019 6:21 pm
I am still looking for one original wing nut. I have one original and one repro, but the repro looks different.
Anyone a source ? Where they used on other Jags, maybe in other places ?
Carsten
#4 Re: C17544 special washer under air intake box wing nuts
Post by Heuer » Sun Apr 28, 2019 10:51 am
I thought the repro's are pretty much exactly the same as the originals - cast brass and cad plated:
https://www.sngbarratt.com/uk/#!/Englis ... 2158125e63
ysmalkie
Poland
#5 Re: C17544 special washer under air intake box wing nuts
Post by ysmalkie » Sun Apr 28, 2019 3:18 pm
David, once again, many thanks!
One more item relating to the plenum are the C4202/2 nuts used all the way from XK120. They were nickel plated on the XK120, but I would probably believe they were cad plated on the e-type?
Would you know if they were they still stamped PPPPP?
Tadek
Tadek
Jaguar XK120 OTS
#6 Re: C17544 special washer under air intake box wing nuts
Post by Heuer » Sun Apr 28, 2019 3:35 pm
Yes, cadmium plated on the E-Type.
The 'P' stamp refers to the tensile strength (BS 1083):
Nut-Grades are : A, P, R, T where minimum tensile strength is:
Grade A = 28 tonf/in
Grade P = 35 tonf/in
Grade R = 45 tonf/in
Grade T = 55 tonf/in
So if Jaguar chose a nut with a Grade P tensile strength for that application they would continue to use it in production unless there was significant change to the design.
I am checking to see why Race Restorations list two washers of the same size (FAS009 and FAS067) but one is twice the price of the other. Could be the thickness - I will report back.
ysmalkie
Poland
#7 Re: C17544 special washer under air intake box wing nuts
Post by ysmalkie » Sun Apr 28, 2019 4:42 pm
Was the PPPP stamped on the nuts in the 60ies?
Tadek
Tadek
Jaguar XK120 OTS
Durango2k
#8 Re: C17544 special washer under air intake box wing nuts
Post by Durango2k » Sun Apr 28, 2019 4:57 pm
I will take a pic of my two winged nuts :-), so we can compare.
Maybe the one I found on the car is the weitd one, and the repro is the better one ?
We‘ll see.
Carsten
#9 Re: C17544 special washer under air intake box wing nuts
Post by Heuer » Sun Apr 28, 2019 5:39 pm
ysmalkie wrote: ↑
Tadek
Yes. More info on nut and bolt markings in Factory Fit if you search: http://forum.etypeuk.com/viewtopic.php?p=56692#p56692
#10 Re: C17544 special washer under air intake box wing nuts
Post by Heuer » Mon Apr 29, 2019 2:15 pm
Heuer wrote: ↑
They got back to me. It was a typo on their web site. The correct washer is FAS067. http://www.racetorations.co.uk/fastener ... asher-p105
Philk
#11 Re: C17544 special washer under air intake box wing nuts
Post by Philk » Mon Apr 29, 2019 3:14 pm
Heuer wrote: ↑
Went on to the website to order and then stopped in my tracks at the delivery cost. Each washer costs 44p including VAT. Delivery for a pair weighing virtually nothing = £5.40!!!
A pity we did not have this part of the thread ahead of Angus' bash..... one of us could have bought a "bulk" purchase of 20 washers (for 10 cars) and each person could have paid £0.54 each in "postage" as we handed them around.
1964 S1 3.8 OTS
#12 Re: C17544 special washer under air intake box wing nuts
Post by Heuer » Mon Apr 29, 2019 3:23 pm
SNGB sell them for 18p each but would still charge you £5+ for p&p. However if you are ordering other stuff just add them to your list: https://www.sngbarratt.com/uk/#!/Englis ... 0de5a7ae80
Or, if you are passing B&Q, you can buy a pack of 10 for £2.58: https://www.diy.com/departments/diall-m ... 008_BQ.prd
Nothing special about them - just repair washers!
