Jaguar E type series 1 wiring loom
juzman
#1 Jaguar E type series 1 wiring loom
Post by juzman » Thu May 02, 2019 10:46 am
Can anyone in the UK share experiences with new wiring looms. Who supplies the best quality?. Who supplies the easiest wiring diagram?. All advice would be appreciated.
Justin. 1966 Series 1. 4.2 E Type. DHC.
#2 Re: Jaguar E type series 1 wiring loom
Post by christopher storey » Thu May 02, 2019 11:24 am
Autosparks are far and away the best for looms - the field is very small anyway now
The best wiring diagrams come from Coventry Auto Components 0247 647 1217
e mail sales@xkparts.com . These books split the circuits down by function, such as panel instruments , starting , fuel , lighting, signalling , fuse boxes etc
#3 Re: Jaguar E type series 1 wiring loom
Post by Heuer » Thu May 02, 2019 12:24 pm
There are also colour wiring diagrams in the Forum Knowledge Base which can be blown up to A3 size and laminated.
#4 Re: Jaguar E type series 1 wiring loom
Post by politeperson » Thu May 02, 2019 4:47 pm
I purchased one from Autosparks recently and I also purchased the Coventry wiring Diagram as well.
The loom is easy to fit and high quality, The price included all this lot and cost about £1k. Lead time is 6 weeks at the moment.
I very nearly did a post about how to lay the loom out in the car, as the wiring diagram does not tell you, it is pretty straight forward though. You will need to buy some female bullets, single and double as well.
The instrument panel daisy chain for the instrument lights is not available, so you may have to use your old one.
JAGUAR E-TYPE SERIES 1 WIRING HARNESS SETSKU: 103SET 1
LUCAS 2 WAY GLASS FUSE BOXSKU: C143 4
JAGUAR E-TYPE SERIES 1 4.2 LITRE WIRING INSTRUCTION BOOKLETSKU: 9191 1
JAGUAR E-TYPE 8-PIN BONNET PLUGSKU: 128-108 1
JAGUAR E-TYPE SERIES 1 BATTERY TO SOLENOID LEADSKU: BC513 1
JAGUAR E-TYPE SERIES 1 STARTER TO SOLENOID LEADSKU: BC514 1
JAGUAR E-TYPE SERIES 1 BATTERY TO EARTH LEADSKU: BC515 1
JAGUAR E-TYPE SERIES 1 3.8 / 4.2 LITRE REVOTEC COOLING KIT - NEGATIVE EARTHSKU: RV-B-JET-S1 1
E-TYPE WIRING HARNESS STRAPPING KITSKU: 166-100 1
E-TYPE WIRING HARNESS CONNECTOR BLOCKSKU: 166-101 1
#5 Re: Jaguar E type series 1 wiring loom
Post by rswaffie » Thu May 02, 2019 5:18 pm
Hi James,
Do you mean the red/white daisy chained wires ? If so, they came in the 'sundries' pack as part of the autosparks full loom kit for my s1 3.8.
regards
Jeremy
#6 Re: Jaguar E type series 1 wiring loom
Post by Jeremy » Thu May 02, 2019 9:28 pm
Same here.
Jeremy
1967 S1 4.2 FHC
#7 Re: Jaguar E type series 1 wiring loom
Post by abowie » Thu May 02, 2019 9:33 pm
The usuals sell the Autosparks looms and for some reason they're cheaper from them.
juzman
#8 Re: Jaguar E type series 1 wiring loom
Post by juzman » Fri May 03, 2019 2:07 pm
Thanks for all the advice guys. So are the Autosparks looms available from say Martin Robey?. Are they cheaper than buying direct?.
#9 Re: Jaguar E type series 1 wiring loom
Post by politeperson » Fri May 03, 2019 2:16 pm
I never got my daisy chain of light bulb holders.
I got a daisy chain of spade connectors!
juzman
#10 Re: Jaguar E type series 1 wiring loom
Post by juzman » Fri May 03, 2019 2:27 pm
Also how do I find the diagrams in knowledge base?. I tried to copy and paste the link to no avail.
Thanks.
#11 Re: Jaguar E type series 1 wiring loom
Post by mgcjag » Fri May 03, 2019 2:38 pm
Hi...whats your name..please try to put it with your car model in the signature area...thanks....go to Knowledge base section......then technical documentation......lots of info thete including diagrams.... Steve
http://forum.etypeuk.com/viewtopic.php?f=16&t=700
juzman
#12 Re: Jaguar E type series 1 wiring loom
Post by juzman » Fri May 03, 2019 3:29 pm
Ok Steve, found it, thanks.
Justin. 1966 Series 1. 4.2 DHC
juzman
#13 Re: Jaguar E type series 1 wiring loom
Post by juzman » Fri May 03, 2019 3:37 pm
Excuse my ignorance David, but do you just print on A4, then take it to a print shop to get blown up?
#14 Re: Jaguar E type series 1 wiring loom
Post by mgcjag » Fri May 03, 2019 4:01 pm
Hi Justin...i have done that....but if you have an A3 printer you can print A3........Steve
#15 Re: Jaguar E type series 1 wiring loom
Post by Heuer » Fri May 03, 2019 8:11 pm
Or email them the file directly. If that is a problem put it on a memory stick and hand it to them.
juzman
#16 Re: Jaguar E type series 1 wiring loom
Post by juzman » Sat May 04, 2019 7:48 am
Hi Andrew,
Have you found other suppliers in the UK that sell Autosparks looms cheaper than buying direct?.
#17 Re: Jaguar E type series 1 wiring loom
Post by abowie » Sat May 04, 2019 9:33 am
I've bought a number of looms over the years and have never bought direct from AutoSparks. I do use them to source wire, connectors etc that the usuals don't stock. They are an excellent resource for this.
SNG Barratt are usually cheaper for looms. I can't speak for Manners with regards to looms because I don't think I've bought one from them.
If you want a custom loom though it is worth dealing with AutoSparks direct. They will make a loom to your specifications, adding or removing stuff as you require.
The other thing worth knowing is that if you ask Barratts and Manners for a discount they usually will give you one. I get 10% off on most things but they will offer this to anyone I think.
When I did this I told them that I was starting a complete restoration. Which was true as I'm now on my 4th. :bigrin:
juzman
#18 Re: Jaguar E type series 1 wiring loom
Post by juzman » Sat May 04, 2019 10:20 am
Ok, thanks, i will look at SNG Barrett.
#19 Re: Jaguar E type series 1 wiring loom
Post by mgcjag » Sat May 04, 2019 10:43 am
Hi Justin...worth noting that with SNG you get a discount for car club membership....whats really good with their web site is once you register with them the prices displayed are with your discount already deducted.....Steve
Robbiee
#20 Re: Jaguar E type series 1 wiring loom
Post by Robbiee » Sat May 04, 2019 12:44 pm
I’m only upgrading one bit of my ‘62 OTS...I’m swapping the dynamo to alternator(probably a dyno look a like one)
My question relates to the charging/regulator wiring changes:
Does the wiring loom change much?
Is it best to have a custom made/altered loom from autosparks OR just get a standard on and alter it as I fit it?
Anyone done this or can advise please?
Robbie
