I have a small coolant leak from the top hose/thermostat housing joint on my Series 2.
After removing the hose I have found the thermostat housing to be quite badly pitted.
Can anyone suggest a suitable sealant to apply to the housing/ hose before reassembly?
Thank you
Coolant Leak
SimonBrown
Topic author - Posts: 196
#1 Coolant Leak
Simon Brown
1969 E Type Series 2 OTS
2013 F Type V6 Convertible
1975 Honda 400 Four
1975 Honda 400 Four
#2 Re: Coolant Leak
Blue hylomar may work but if the life are large....hmmmm....
#3 Re: Coolant Leak
You need to fill the divots to get a smooth surface for the hose to seal against. Good quality silicone, JB weld or similar, or TIG filling with aluminium rod will all work.
