Have a 71 series 3 1S20008. Trying to locate the location of the turn signal flasher. This is a left hand car with air. Sounds like it’s behind or below the cubby box.
Chuck
Turn signal flasher
#3 Re: Turn signal flash
Thanks. That helped out a lot. The problem turned out to be high resistance connection at the fuse holder.
The voltage appear to be there but not enough current to allow the flasher to “trip”.
