Post
by PeterCrespin » Sun Nov 10, 2019 9:59 am
Er, the instrument panels folded down easily enough when the cars came down the line. They still do on any car maintained or re-trimmed to factory spec.
The only time I’ve had trouble is when I (or a PO) have used too much sound or heat insulation around the tunnel or console, or not fastened the tunnel cover and/or centre console low enough. Any one (or two, or all three) of these errors result in the radio console sitting too high to clear the fragile legend strip. I’d also be a bit nervous of riveting brittle plastic, although with care I’m sure it’s doable.
Of course nobody wants to peel back nicely-applied Dynamat/Koolmat or even the jute under plush new carpet, but if the car is over-trimmed the panel doesn’t fold down..So, is it better to fix the cause or do a work-around? Something to think about if you’re tempted to buy 3/4” jute instead of 1/2”, or whatever...
