peters3103
Post
by peters3103 » Wed Jan 08, 2020 8:46 am
Ok rivet counters, should this part be silver or hammertone. Can’t find anything in the Haddock bible apart from a pic which looks matt silver.
JCNA judging guide:
Is what they refer to as “BASE (TO CARBS)” the intake trumpet?
Cheers,
Post
by abowie » Wed Jan 08, 2020 9:14 am
The new one I bought recently from SNGB was hammertone.
peters3103
Post
by peters3103 » Wed Jan 08, 2020 9:58 am
Thanks Andrew, mine is currently hammertone (that’s not mine pictured above btw) but I thought I’d repaint it while its off. I guess if the SNG supplied one comes hammertone that would be correct.
Robbiee
Post
by Robbiee » Wed Jan 08, 2020 10:52 am
No evidence of hammer finish on my 2 original ‘62 trumpets
I’ve repainted with smooth silver (slightly metallic) same as triangular Allie box
Robbie
288gto
Post
by 288gto » Wed Jan 08, 2020 9:42 pm
peters3103
Post
by peters3103 » Wed Jan 08, 2020 11:05 pm
Well I’ve dropped the ball there, I should’ve referred to the Factory Fit first. Must remember that in future. It certainly appears, on the red car at least, that the plenum is hammertone and the trumpets are silver. That’s where I must’ve seen it previously.
Robbiee
Post
by Robbiee » Thu Jan 09, 2020 6:48 am
That sounds correct
Trumpets smooth silver and...
I just checked my plenums and they are both hammered finish...quite subtle silver though ..not that vey “speckled” finish that is sometimes seen
Hope that helps
Robbie
peters3103
Post
by peters3103 » Thu Jan 09, 2020 8:21 am
Cheers Robbie.
ysmalkie
Post
by ysmalkie » Mon Jan 13, 2020 6:43 am
Would it not be the same silver as used on the headlamp scoops?
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
peters3103
Post
by peters3103 » Mon Jan 13, 2020 8:16 am
I ended up using the Eastwood’s cad colour aerosol that I bought for my front suspension parts. I’m happy with it.
