Currently rebuilding my S2 cylinder head due to a noisy exhaust tappet, so having removed the exhaust cam after noting down the clearances I measure the roundness and thickness of the existing followers which are found to be round within .001" (good) and the thickness 1.222/3". I ordered 6 new followers and the necessary shims and started to put the head back together. Cylinder numbers 1 to 5 cylinders go ok, new shim and new followers found to be 0.222" thick then I measure the thickness of the last new follower for No 6 and find it 0.007" thinner at 0.215" I don't have a thicker shim to make up the difference. So I searched here and the Jag-lovers forum and found the following (thanks to Bob_K1)
"The subject of tappets is unfortunately somewhat more
complicated (guess how I know?). The original XK120 and 140
tappet C.7312 was 1.375 inch tall. The XK150 received a
modified tappet C.3712/1 that was 1 inch tall. This was done (I
understand) to prevent ‘‘rocking’’ of the tappets in older
engines with some wear.
The later tappet C.44010 went back to the shorter dimensions of
the original C.7312 version. This in itself may not be a
problem but unfortunately the deck of C.44010 (0.222 inch) is
thicker than C.7312 and C.7312/1 (0.215 inch) and this 0.007
inch implies that you have to move down 7 steps in choosing the
correct shim! In some cases you may require a shim even thinner
than A (0.085). Although they can be made to size, looking for
a matching tappet C.7312 is much easier
Bob K. (aka Bobine)"
So It looks like i have received 5 of the later C44010 followers and 1 of C7213/1 evem though the supplier site claims that C44010 and C7213 are interchangable THEY ARE NOT, which means I can't finish my head until I have another C44010 follower. I know I could just get a 0.007" thicker shim but imagine what would have happened if I'd just assumed that the followers were all the same I would have ended up with a clearance of 013" not 006" and have to take the cam out again.
