Hi Geoff,
The two numbers i have quoted above are the straight type and the curved type - which covers both of the vent nozzles.
There is the actual vents themselves which are available as:
https://www.sngbarratt.com/uk/#!/Englis ... f2d101989f
but are (currently) quite expensive and available only as a set.
Hope this helps and i am not missing anything - do feel free to DM me if this doesnt cover what you are expecting.
Demister Vents
JulianBarratt
#21 Re: Demister Vents
MD at SNG Barratt Group
#22 Re: Demister Vents
Hi Julian, thank you for clarifying things. I was mistaken in thinking there is one long central vent nozzle not two straight ones together. My mistake, sorry.
Now we've got to persuade you to make the linked vent set a little less expensive
#23 Re: Demister Vents
Hi Geoff...
or convince you to pay a bit more
#24 Re: Demister Vents
I had some reversed engineered and 3D printed using ABS-M30, yet to fit them so fingers crossed. Also made them slightly thicker as ones I have seen were very brittle. Not cheap but we all do daft things at times!
#25 Re: Demister Vents
Hi there
I’d use your name but don’t know it
I see you have reverse engineering of the vents …. Did it work well?
Are you prepared to make the cad files available so I can also make form ….. mine are totally unserviceable….OR can you make me a set for reasonable $’s
I see no benefit in doing the same job over
Danny Lee 0412327197 Melbourne
#27 Re: Demister Vents
+1 also
Al
Series 1, 2+2
undergoing renovation
Series 1, 2+2
